Chris NottMonster Motorsport
Results 1 to 15 of 15
    Apr 2004
    1,139
    Noisy drivers door seal
    I know there has been plenty of posts about this in the past and is a common problem amongst A3's (why?).
    I have had two A3s now and the first one didn't have this problem at all ever, my current one hasn't had this problem wither... until now!
    Did anyone actually get to the bottom with it with a 'proper' tried and tested fix (by audi or otherwise) i know there were lots of DIY potential remedys banded about but did it ever get properly solved to the point where dealers know exactly what to do to fix this problem? Last time i read a post - bending the door was mentioned!!!!
    Apr 2007
    421
    The only solutions I've heard of are crayons or new seals.
    A3 2.0TDI 170 Sport
    Apr 2004
    1,139
    crayons?
    Apr 2007
    421
    Yup, crayons. Not sure how long it cured the problem for but it's a cheap fix, albeit a temporary one!
    A3 2.0TDI 170 Sport
    Apr 2007
    421
    I do hope I haven't just made that up!
    A3 2.0TDI 170 Sport
    Apr 2007
    421
    Here's a link to Mikey's post.
    Creeky door and Crayon saved my life.
    A3 2.0TDI 170 Sport
    Apr 2006
    england
    754
    Smile
    http://www.audi-sport.net/vb/showthr...298#post558298
    read my posts, and trust me it will work, ask MIKEY
    27,114
    When does it squeak, when driving, is it the black rubber seal the door shuts onto?
    have you tried lifting the door for few seconds from the bottom to rear corner to adjust the hinge by literally mm, dont put loads of force on it, just see if this stops it rubbing
    Bit more info would help me to understand the fault more.
    Ahhh do you mean the window seal?
    Khufu's Avatar
    West coast of Scotland
    5,693
    my old a3 creaked under the door on the sill after I cleaned them with meguiar's trim detailer. Had to clean it off. Did a good job of the black exterior trim though. Could you also use back to black on the seals to stop them creaking?
    Sep 2006
    Surrey
    1,224
    Is it a squeeky sound? I've recently got that from my passenger side but couldn't pin point where it was.
    It's a squeeky sound that I have
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    Apr 2006
    england
    754
    Quote Originally Posted by emzino View Post
    does the sound go away when you drop the window a mm down? if so read my post
    Apr 2004
    1,139
    no its more like a twitchy sound that 'seems' to be coming from the top edge of the door - its only started over the winter (ie it was fine last summer/autumn). It happens when i go over bumps and also when i go up ramps at funny angles, ie driveway slope etc - sounds weird but its almost as if the car is twisting/flexing slightly and this is causing the door to rub against the rubbers or something - i dont know.
    It's booked in for its first service in a couple of weeks so getting them to look at this along with squeaky door handles(!!!!!) (audi build quality? hmmm) so see what happens.... whats the bet.... we couldn't hear anythign sir?
    27,114
    So if you open the window slightly when it does this, does it go away, also try getting some wd40 or infact a small dab of grease just for testing purposes & stick it over the rubber seal in the corner & this will tell you if its just the rubber on metal making the noise fella, problem then found & can then resolve
    Apr 2004
    1,139
    are we talking the larger inner rubber seal here or the outer one that is fixed to the door frame and sits on the paint?
    27,114
    Do one at a time mate then this will show you where fault lies, so if doesnt work on one then try other, bit of fault analysis in the rain, well is down here anyway, lol
