AH FabricationsEM Tuning
Thread: sat nav help
    Sep 2006
    383
    sat nav help
    I have sat nav plus with mfsw and gsm phone install,now am I being exceedingly thick but when I try to use the speech command all I get is phone options,
    Accorrding to the manual if I use the command
    Help Navigation
    Help CD
    Help Radio
    I should get various options but all I get are the phone help options each time.
    Manual options work fine
    I use a bluetooth phone and that works ok,only thing I find a bit odd is that the original phone cradle is fitted on the dash and not centre consul
    (car is ex demo S3 facelift)
    Any thoughts anyone
    Dec 2008
    249
    It's probably cause SDS hasnt been enabled on the RNS-E. Search for Speach diagloue System on here or audiforum.us and all will be explained
    Sep 2006
    383
    Quote Originally Posted by fizz View Post
    Thanks for that,looks like its not enabled so is this a main dealer chargable option or is it possible to have it done elsewhere,if so where (south uk)
    JohnS3's Avatar
    Oct 2004
    3,021
    Easy, wire your mic to the rnse, then on to the Bluetooth module, you'll need a couple of repair wires. You'll need to break into the mic wire runnng up the a pillar. Run patched firmware to install the sds hack, then record your bluetooth module for voice control via rnse. Do a search there's a guide on here somewhere. Your dealer will most likely tell you it can't be done!
    26,722
    Yeah John's correct, you need to rewire mic through rns to btooth module cause at moment you have voice commands for the btooth as mic is going to this presently, need to update firmware via dvd which I can email to you if need be & also code the car for functionality, I'm in east sussex if you cant manage it all, I can get repair wires, dvd & have vcds to code it all.
    Stealer wont touch with barge pole 100%, its a factory order only on new cars
