EM TuningMonster Motorsport
    Jan 2009
    Update US NavSat to Europe maps/info
    Hello everybody,
    I may be getting an A3 Sportback equipped with the US version of RNS. How easy or difficult would it be to update it with the maps and road info of Europe? Would buying the proper DVDs from ebay do the job or should I have the dealer do that?
    Thank you in advance
    Dimitris
    Jan 2009
    Hello again,
    I have not received any response. Does by any chance anyone has experience with converting the american RNS-E to the European standards?
    Thanks again
    Dimitris
    jmohide's Avatar
    Dec 2007
    Bristol
    131
    If you still get no luck, this place might have the answer
    http://audiforum.us/rns-e/
    "I don't sweat because I use Lynx Africa"
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    not sure if you need any form of vagcom or leads but all the maps are on dvd so just get the european ones... ebays should be fine just make sure there original as copys will burn your laser out in the long run
    JohnS3's Avatar
    Oct 2004
    3,021
    It can be done but you need to make some hacked firmware CDs. All the info is most likely available on Audiforum.us in the RNSe quicklinks section as mentioned above.
