Chris NottAH Fabrications
Results 1 to 27 of 27
Thread: DSG Failures
    Jan 2009
    106
    DSG Failures
    As I consider myself to be pretty "normal"...I'm starting to twitch a bit prior to picking up the car on friday. Should I have gone for a manual instead of DSG? So I go online!! (bad move), it seems everywhere I go there are horror stories re-DSG. 4k for a new box 2k for a mechatronic...whatever the hell that is? I fully understand they have probably sold 100'000s of DSG's and there are bound to some failures. So I was wondering how many peeps on here have had to fork out big bucks for DSG problems...And hopefully put my mind at rest if only a little....
    regards
    dave
    Oct 2008
    Telford
    2,488
    I've not heard much. Same with anything on the net, people always like to moan! You wont get people starting a thread saying how good their DSG is so you will always pick up the negativity first.
    Chill aout a bit, I never give it a thought until it was sat on my drive!
    B6 1.8T Avant s line gmbh
    Jan 2009
    106
    Yeah your probably right. Who was it that said " a little knowledge is a dangerous thing"?
    regards
    dave
    I'm on my second new A3 with a DSG greabox and have had no problems at all.
    The mechatronic by the the way is the unit that sits on the gearbox and controls all the gearchanging and the two clutches.
    Here is a link to a PDF file of an article that describes the DSG and how it works which may be of interest.
    DSG Gearbox
    Dave R (h5djr)
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    I had no problems with my DSG, I just didn't like it (putting it mildly...)
    It has to be said though, I wouldn't fancy owning DSG as the miles start mounting up.
    Even DSG's most vehement supporter, namely David (above), is trading in his car at relatively low mileages.
    You know a manual car is going to need a clutch at some point.
    You can budget for it, using places that specialise in fixed-cost clutch renewals.
    God knows what clutch replacement(s) would cost for a DSG.
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    A member on here is putting 340lb of touqe through his standard DSG box and his is going strong!
    They are very underated from what I've been told - they can handle a fair bit more than what audi give them from standard.
    I wouldnt really worry tbh. If your that weary of it, then maybe an aftermarket AA warranty?
    But mine done 60k with no issues.
    So long as the oils changed on the spcified intervals andthe cars fully serviced, i wouldnt really worry!
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by kaz219 View Post
    I wouldnt really worry tbh. If your that wary of it, then maybe an aftermarket AA warranty?
    Warranties won't cover you for clutch/es replacement though, will they?
    Even if they cover 'wear and tear', clutch plates are classed as consumables, aren't they?
    So you'd be covered for a DSG failure, but you'll still (at some point) have to stump up for the twin clutches to be replaced.
    kaz219's Avatar
    Jun 2008
    1,796
    Quote Originally Posted by bowfer View Post
    I meant if the actual DSG box was to fail itself - they should cover it.
    Clutches - that is wear and tear - doubt any warranty will cover it but a member had his flywheel replaced on the warranty as it broke... Couldn't that be assicated with wear and tear :S
    Vagcom'd too
    There is a big difference between a normal single dry clutch in which the friction material wears out and the twin wet clutches used in the DSG. Here is part of an article on the DSG which explains:
    "Although wet or dry clutches can be used in a dual-clutch transmission, BorgWarner specified the former. Unlike a dry friction clutch that consumes its friction material and requires eventual replacement, a wet clutch is bathed in transmission fluid, which lubricates and cools it, allowing greater longevity and more consistent shift quality over a wide range of operating conditions."
    I have no idea how long the wet clutches are designed to last but I'm pretty certain it will considerably longer than a normal dry friction clutch. Also there are two wet clutches each doing half the work so in theory they should last twice as long anyway. The system used to control the DSG also means that things like 'riding' the clutch etc are eliminated thus removing another cause of wear in a normal dry clutch.
    When I'm next at my dealers I will ask one of the Masters Techs what is the highest mileage they have seen to date on a DSG equipped car.
    The highest mileage I've had in recent times on a VAG car was 60,000 miles on a manual gearbox 2.8 Golf VR6 and that did not show any sign a clutch wear.
    Personally I would expect the two wet clutches in the DSG to last at least 100,000 - 150,000 miles before showing any serious signs of wear.
    Dave R (h5djr)
    Jan 2009
    106
    Prior to buying this car I was going to look at another 2.0TFSI but something cropped up and I didn't go. It went something like this. Audi A3 2005 55 plate 2.0 TFSI. DSG, full leather, sat nav, etc etc, excellent cond full audi history. High on the miles but mint condition car...7999....
    High on the miles................How many miles you might ask?.....134,000!!!!!!
    And the guy said it drives like new and he'd put a full 12 months warranty on it!!1 134,000 miles in 3 1/2 years.....now that's motoring.
    regards
    dave
    Not anymore - Back 2 BMW (shh)
    Aug 2006
    Norwich, Norfolk
    357
    VW say that the DSG clutches should last the "lifetime of the vehicle" whatever that is and effectively not need replacing under normal operating conditions. Although, I have to say, presumably one is always de-clutched - surely that must put extra strain on the springs? I guess that must have been thought about when it was designed...
    Although of course, the new 7 speed DSG is a dry clutch arrangement. Why the change I wonder?
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    Quote Originally Posted by a3norwich View Post
    No need for any service on the box, no oil change required every 40K.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    Jan 2009
    106
    Just found out the car had a DSG oil change at 36k miles, so I should be ok for another 6k miles. They said 170.00 inc vat is that about right?
    regards
    dave
    Further to my earlier posts. I emailed Warranty Direct, one of the leading suppliers of extended warranties, and they confirmed this morning that the wet clutch unit on the DSG is not considered a 'wear' item and would therefore be fully covered by their extended warranties. On a manual gearbox the clutch friction plate would not be covered.
    Using my current A3 as an example and with any work that was needed being carried out by an Audi dealer, they quoted 390 for a years cover.
    Dave R (h5djr)
    Jan 2009
    106
    390..Hmm! There are 3 or 4 on e-bay from 500-900 so I feel a little easier about it anyway. But thanks for finding the info. As an aside, the AA will do it for 199 for one year. their standard warranty cover.
    regards
    dave
    Quote Originally Posted by firebobby View Post
    regards
    dave
    The AA's price is probably using their own choice of garages rather than Audi dealers. I know Warranty Direct would have also done for less if I hadn't specified I want any work that was needed done by a dealer.
    Dave R (h5djr)
    Jan 2009
    106
    Ah!! Well to be honest, I use a local garage where I have gone (and worked for in the past) for over 30 years. In fact one of his customers has a A.M. vantage and he takes it there for servicing!! He does use dealer parts though.
    regards
    dave
    Rafkoo's Avatar
    Feb 2008
    S London
    64
    That's a very good price on the warrenty!! I was quoted 700 last year (inc DSG cover)....
    A3 3.2Q Sport DSG
    "Knowledge is power, tuning knowledge is horse power"
    just017's Avatar
    Apr 2009
    438
    just as this is quite relevant now, today Warranty Direct gave the go ahead for my Flywheel on my DSG as it failed. Thank god they did too because i didnt realise you can only get the flywhhel used in the DSG cars from the dealer. 528quid EXCLUDING VAT!
    Audi A3 2.0TDi S-Line - Bose - AMD Remap - Pipercross Performance air filter - RNS-e Retrofit - RS4 style Alloys
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    And how much has warranty direct cost over the time you have had it ? not the 700 rafkoo was charged i hope !
    just017's Avatar
    Apr 2009
    438
    Nope it's 17 a month and I've had it since March. So thats about 70. the total invoice for the new Flywheel came to 1086 , so I think that's a rather good decision to get warranty if you ask me.
    East Sussex
    617
    Well, and all this way down still not read anyone who has had a DSG failure.
    just017's Avatar
    Apr 2009
    438
    Yeah just to clarify the DSG is fine,it's just the flywheel. However I have had the problem where the DSG completely disengages and doesn't go into any gear, but only 2 times in over a year
    Quote Originally Posted by just017 View Post
    http://www.audi-sport.net/vb/showthr...746#post929746
    However, if the DSG changes can be customized to individual requirements, even in the Diesel I think DSG should be good - just wasn't for me.
    Sep 2009
    Trotters, Peckham
    539
    DSG with HPA flash FTW!!!
    May 2010
    20
    I went with a warranty direct warranty aswell for about 400 a year. It's piece of mind if nothing else. There are lots of warranties out there but most of them list the parts that are covered where as warrAnty direct and warrantywise just cover everything.
  28. #27
    just017's Avatar
    Apr 2009
    438
    HPA flash?
