Volks AutosSky Insurance
Results 1 to 7 of 7
    Trev241's Avatar
    Mar 2007
    229
    DRL plus rear lights
    Is it possible to change settings on my 2007 S3 so that the rear lights are on when DRL's are switched on, asked my dealer today but he don't have a clue.
    Is this the so called Scandinavian setting I have heard about ?
    Trev
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Yup - that's right. There are 2 settings in vcds (vag-com), north american (i think) which is fronts only and then scandinavian which turns the rears on as well.
    Jon
    Now A3 less......
    Trev241's Avatar
    Mar 2007
    229
    Quote Originally Posted by redbutcher View Post
    So the dealer should be able to do this with the Audi diagnostic setup ?
    Trev
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Yup - though they might be cheeky and charge you for it!
    Either that or see if someone with VCDS lives near you - we're a friendly bunch and stuff like this can easily be done at meets or for a few beer tokens.
    Jon
    Now A3 less......
    26,722
    Yeah just go into 09 long coding & enable scandinavian, its easy peasy if you have VCDS, another reason to buy a genuine cable, stealers will charge you for that aswell most likely, why not spend the money on the cable itself so anything else you can do yourself & pays for itself after the 1st use on many occassions & anything after that is free huh
    Trev241's Avatar
    Mar 2007
    229
    Don't have the kit so will have to get a kind person with VCDS to do the job or beg the stealer to do it for nothing.
    Trev
    26,722
    Then might I suggest you consider purchasing it, then can do all these things yourself.
    Cost me 265 even though can get for less & I can assure you its paid for itself 100 times over easily
