Volks AutosMonster Motorsport
Page 2 of 2 FirstFirst 12
Results 41 to 50 of 50
Like Tree1Likes
Thread: How easy is it to retrofit auto lights&wipers?
  1. #41
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    I've got glass for the mirrors if anyone is interested
  3. #42
    Apr 2010
    Nottingham
    230
    Kufatec loom has shown up! Now to start trying to get my head around the wiring.
    Does anyone have parts numbers for the CH/LH connector and repair wires i'll need? I have the auto-light switch with the CH/LH button, just need the connecting half.
    '07 Phantom Black S3
    Superchips Bluefin Stage 1
    TTRS FBMFSW
    MY11 Rear Lights
    Auto-lights/Auto-Wipers/Auto-dimming rear view mirror/CHLH retrofit
  4. #43
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    i 'think' the part you are looking for is 4D0971636
    i can confirm this when i get home later tonight as i have the invoice for that part at home.
    here are some more helpful links to other threads on the subject
    http://www.audi-sport.net/vb/new-a3-...r-install.html
    Auto Lights question
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
  5. #44
    Apr 2010
    Nottingham
    230
    I have the same problem as what you described below. How did you sort the issue?
    Cheers.
    Quote Originally Posted by itwasntme187 View Post
    BIG PROBLEM:
    When i enable the light/rain sensor on VCDS a error message comes up on the DIS saying that the light and rain sensor is defective.
    There are 2 error messages that come up on VCDS but i am now at work and dont have the error log with me. 1 is about the actual sensor and the other is about the canbus connection saying no signal.
    Can anyone advise which pin is no.3 on block F so i can confirm that this is connected properly?
    thanks
    TTRS FBMFSW
    MY11 Rear Lights
  6. #45
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    that problem with the light/rain sensor was an issue with the power from the fuse box... it was loose
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
  7. #46
    Apr 2010
    Nottingham
    230
    Just to follow up, turned out my earth wasn't happy. Moved the earth to a different bolt and now the auto-dimming rear view mirror and rain-light sensor appear to work.
    I've just tried the auto lights and they seem to stay on all the time. Sounds like you had the same issue in the past and it was more luck and a bit of fiddling that sorted it out!
    TTRS FBMFSW
    MY11 Rear Lights
  8. #47
    Dec 2008
    25
    Can you tell me which bolt did you take your earth from?
    I'm having the same issues, the DIS is displaying that the light sensor is defective, and on VCDS i have two errors, one about the sensor and another one about the canbus connection.
    My earth is a "splice and join" to an existing earth wire, should i move it to a bolt?
    The thing is that i have 12v at the pins on the rain and light sensor, i checked.
    I would try any possible solution, before having to replace the sensor..i am still hoping that it's not defective.
  9. #48
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    i use the bolt up just above the steering column to the right above the CE module. if not you could use the OEM grounding point just behind the carpet on the right side of the car behind the bonnet release lever
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
  10. #49
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    Hi Guy's, so on an OEM install how would these wires be attached? Would they really be spliced too?
    2012 RS3 Ibis White | Black Styling Pack | Black Roof Rails | Bose | Cruise | Tyre Package | Privacy Glass
  11. #50
    27,033
    In what respect spliced, you mean if installed from factory, if so then its all built into the cars original looms, if doing after purchase then new loom added with pins on ends to plum into connectors.
