Chris NottBadger5
Thread: S3 Washer jets
    eugegall's Avatar
    Oct 2008
    Guildford, Surrey
    66
    S3 Washer jets
    Hey,,
    I recently had the washer jet pump replaced on my S3. Should the water come out
    a) 6 Single lines of water with no spray
    b) 6 Spraying?
    thanks
    27,026
    what do you have now then?
    Cause they're usually lines based on numbers of holes on the 8P, the passat has the spray fans which is a wide fan spray not individual lines & also I have bought these to fit to the car, but the jet pump wont change the type of spray as the jets wouldnt of been replaced in front of the windscreen huh
    Do you mean the actual main water bottle/pump or the headlight washer jets or the windscreen jets?
