Sky InsuranceVolks Autos
    A3 3.2Q Sport
    Jan 2009
    73
    Ignition Power for Stereo on Concert...
    Hi Guys,
    I'm trying to get a ignition signal for my parrot hands free, it seems that theres not an ignition power going into the basic concert, it seems there is a Phone and satnav output from the radio, but i think they are both constants also?
    Is there anything i can pull from the radio for ignition power or do i need to grab a line from the fuse box and if so does anyone have a recommendation for where to pull it from?
    Sam
    Jan 2007
    Hampshire
    1,155
    Using a feed from the fusebox is the easiest way.
    A6 3.0 TDI.
    A3 3.2Q Sport
    Jan 2009
    73
    Quote Originally Posted by Issac Hunt View Post
    boo might have to pick up a piggyback fuse thing.... any recomendations on which fuse to use?
    I have a MicroGo Speed Camera locator which is wired to come on with the ignition and I have it connected to fuse position 45 in the fuse box at the end of dashboard.
    Dave R (h5djr)
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    There isn't a switched live behind the radio as it it switched by CAN.
    As Isaac says the fuse panel is your best bet. If you want a neat job you can use a repair wire in the back of a spare slot.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    Dec 2006
    Ireland
    2,538
    これで、ここでは、少数の歴史と語ったが必要だ 無名の英雄 この土が削除されます ある人は、継承はされています 造幣局からの輸入 人々の多くがないのにネウルエウンイ 事実、この老いたहेごみमेरे 彼は帽子にゴミ収集した これは、うわっイレオルスがズボンです そして彼は、フラットに住んで協議会
    彼は'真のनानाである 大きな皿の後に起動チクヒギル 彼はउन्हें得ることができる職業を持って 彼は根が何उन्हेंデイジー電話
