Volks AutosSky Insurance
Results 1 to 14 of 14
    David's Avatar
    Owdee A-free
    Aug 2008
    Lincoln
    101
    Changing bulbs...
    My dipped beam bulb has blown, so I need to replace it. But I can't work out how it's done
    Any ideas? Had a quick search but couldn't see much....
    Cheeeers.
    Which model and year do you have. When I know that I can give you a link to the relevant pages from Elsawin.
    Dave R (h5djr)
    David's Avatar
    Owdee A-free
    Aug 2008
    Lincoln
    101
    Sorry ~
    2004 2.0 TDi.
    Elsawin pages for both dip and main beam bulbs below...
    change halogen bulbs - dip
    change halogen bulbs - main
    Hope these help. If you need any more information let me know.
    Dave R (h5djr)
    Oct 2008
    Telford
    2,488
    Read the manual, its quite clear in there!
    From what i remember, you just have to push down on the bulb holder and it clips out. One of the easiest cars I've owned to change a bulb in. Even my chubby fingers found it quite easy!
    B6 1.8T Avant s line gmbh
    Quote Originally Posted by Lee_R View Post
    I wouldn't be certain but if I remember correctly from when I owned a 2004 2.0TDI the manual did not give any details of how to change the headlight bulbs. It is certainly inincluded in the manual for my current 2007 model but I think the 2004 manual just said visit your dealer.
    Dave R (h5djr)
    Oct 2008
    Telford
    2,488
    Mines a 54 plate and it has a full pictoral guide!
    Mine would have been an 04. Perhaps that's when they changed to giving more details.
    Dave R (h5djr)
    Nov 2008
    44
    Hi h5djr, thanks for the guide I've read on other forums that the headlight itself needs to be removed but I'd rather avoid that if possible. I haven't tried the Elsawin method which seems too easy to be true. Shouldn't take longer than a couple of mins right?
    Just a question re the following
    Remove bulb -1- from spring clips -arrows-.
    Detach electrical connector -2- at dipped beam bulb.
    when you push the clips in are you removing the actual bulb or the housing? By detach electrical connector do you mean simply remove the bulb from the housing?
    Cheers.
    Quote Originally Posted by MixedUp View Post
    Cheers.
    Pushing in the spring clips just allows the bulb to be removed from the housing. I've found it better to leave the electrical connector on the bulb until it's removed as it gives more to hold on to. Also I put the electrical connector onto the new bulb first and then put it back in the housing as it makes lining up the tabs on the bulb with the slots in the housing much easier. Make a mental note of the position of the electrical connector before you take it out and then you can alight it in the same position when you put the new bulb back unto the housing.
    Dave R (h5djr)
    Nov 2008
    44
    thanks. Is it easy to hold the spring clips in the 3 areas indicated with arrows with one hand? Do you think there's a chance I could break something.
    Do you know why a lot of people a recommending to remove the entire light by undoing the 4 torx screws?
    Oct 2008
    Telford
    2,488
    Wheres the spring clips?
    Just take the rear cover off, stick your fingers in and locate the plug, push down on the plug and it will clip away. Remove the plug with the bulb still attached, (as below) swap and pop back in but this time clip up to locate the bulb
    Its a 2 minute job for each bulb! Just give it a go!
    Matt's Avatar
    Jul 2006
    Cumbria
    1,416
    Its the worst car I have owned for changing the bulbs. It took me ages to change mine. Theres no room at all to get access.
    Couldn't even find how to get at the sidelights so I haven't bothered changing them for some nice white ones like I wanted.
    Sold: A3 2.0 TDI 170 S-line | Full leather | BOSE | Phantom Black | Bluefin
    Now: Mini John Cooper Works
    Jul 2012
    Just wanted to say thanks for the above tips, am happy to say that I as a complete novice managed to change the dipped headlight bulb! I'd recommend Elsawin's links above as the best place to go. Bit of fiddling around needed as you can't see inside the housing but that's all.
