Monster MotorsportEM Tuning
Results 1 to 24 of 24
    edition's Avatar
    Nov 2007
    1,417
    SD Cards for RNS-E
    Hi,
    Seen these http://www.amazon.co.uk/Transcend-Fl...2905087&sr=8-3
    They ok for RNS-E unit?
    Cheers,
    Aug 2005
    West London
    850
    Yes they work fine. You can use 4gb cards in the rns-e but you have to make sure they arent HC cards.
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
    edition's Avatar
    Nov 2007
    1,417
    Roughly how many tracks would i get on the ones i linked?
    Cheers for teh help!
    26,717
    well rns handles between 400-512 files
    edition's Avatar
    Nov 2007
    1,417
    Is that per card?
    26,717
    Yeap so if running at low bit rate you'd prob get away with 1GB cards, I use 192kbps all time & 4GB cards but nowhere near full up, I also have a 1GB card & that is fine, 128kbps is also good enough
    edition's Avatar
    Nov 2007
    1,417
    Thanks just ordered one, so i guess we shall see how i go on!
    Me being a computer novice how do i make cd's into mp3 files? Also can you convert i-tunes files (i.e purchased off i-tunes) into mp3?
    26,717
    windows media player has a rip feature, insert cd then go into windows media player & then click rip at top, in default windows settings it should create the album/track in the My Documents Music folder for your username, but make sure you goto Tools/Options in windows media player & the rip tab & make sure its set to MP3 not WMA as the ripping format so you get mp3 ripped tunes for your cards, cause rns doesnt support anything but mp3 in the sd slots
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by edition View Post
    iTunes tracks are protected with Apples fairplay DRM and are in .m4a format so can't be converted into .mp3. As a dodge you can burn the tracks to CD with itunes then re-import them as mp3s.
    HTH
    JohnS3's Avatar
    Oct 2004
    3,021
    I've just bought some of these -
    http://www.7dayshop.com/catalog/prod...ucts_id=102042
    as my cards keep finding their way into photoframes and cameras...
    26,717
    Well they're drm free now, so cant you just download them again through itunes, as I dont use itunes store etc I dont know how they work interms of allowing you to get music again if lost
    I'm sure there's an m4a convertor somewhere, but are the drm free tracks now m4a or mp3 is the question as they've now opened up the store to other players I believe, my daily tech updates have told me.
    JohnS3's Avatar
    Oct 2004
    3,021
    You can buy DRM free tracks now, but they cost more! Or you can upgrade the tracks you own for around .20p each IIRC.
    JohnS3's Avatar
    Oct 2004
    3,021
    Anyway, busy weekend doing a double DIN conversion Mr E???
    edition's Avatar
    Nov 2007
    1,417
    Hehe no hopefully get the cables tuesday. Can check the code/unit then.
    If its all ok i will be doing it next weekend hopefully!
    p.s thanks for the files i got them cheers!
    edition's Avatar
    Nov 2007
    1,417
    Right got them working on the machine ok but i'm a little confused how to best lay out the songs on the card.
    I have done it under files i,e
    Artist
    Song
    But it only seems to show up the album name not artist...
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    The way I sort my music on the SD card and in my music library is I have a folder with 'Artist-Albumname' then in the folder '##-Trackname'.
    Navigation on the RNS is easy then as it's all in artist order alphabetically and then as long as you have the track number as 2 digits the RNS with play them in track order.
    8P2 S3
    royjk's Avatar
    Apr 2008
    167
    Two bits of free software that are handy to have are a tag editor & a play list creator. I use Mikey Magic Technologies Tag Editor & Oddgravity Playlist Creator 3
    A3 CABRIO S-Line 2.0 TDI DSG
    Liquid Blue-Blue Hood. Celtic Tunning Remap with E Motion -RNSE-Seperate DVD Player-100gb Portable Hard Drive-USB-Phone Prep-Exnon Adaptive Lights-Heated Seats-Lumber Support-Acoustic Parking-Light & Rain Sensors-Interior Light Pack-Storage Pack-Cruise Control-Folding Dipping Mirrors-Interior Auto Dipping Mirror-Bose-Hill Hold-SDS-FBMFSW - Alpine iPod Controller
    Jun 2007
    Cheshire
    95
    I've just tried copying some music over from iTunes (CD's that I put on, not purchased) and they are showing as "Nokia Music Manager" rather than MP3 for the type of file when on the SD Card.
    Any ideas? Cheers
    StagsyA4
    Audi A4 (B7) 2.0 TDi S-Line (140 bhp), Saloon, Moro Blue Pearl Effect with...
    Black Leather w/ Alcantara | Rear Parking Sensors | BT Handsfree w/ iPhone 4 Dock | RS4 Pedals | RNS-E | Tints
    To come: OEM Xenon's | FB Steering Wheel | Centre Armrest | Bluefin | New RS6 rep's 19"
    Jan 2009
    19
    old car Audi a3 1.8T
    new car Audi a3 2.0 TFSI Quattro S-Line sp manual gears black 18" wheels Cruise control Rain Sensor, Light Sensor and Auto Dimming Mirror Folding Mirror Multi Function Steering Wheels. RNS-E Digital Tv Tuner
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by StagsyA4 View Post
    Any ideas? Cheers
    Have a quick check in iTunes, look in the preferences to see what the default file import format is, it may be set to AAC. If it is you'll have to convert your tracks to .mp3, you can do it from the advanced menu. But you'll end up with the same track listed twice, one aac, one mp3, so delete the right one!
    If the file extension is actually .mp3 you should have nothing to worry about. Sounds like NMM has nicked the .mp3 file association in Windowz.
    Give it a try!
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    I recommend media monkey for file conversion software and for renaming many tracks. For example if I want to rename a whole album so the filename is ##-Trackname.mp3, once it's set up the first time then every album takes a few seconds. You can call it what you like of course. Artist-Album-Track#-Trackname for example, again just a few seconds to do a whole album.
    Also for most options you can choose to replace the original file or create a copy in a different folder. Even though it has a silly name it's bloody good software!
    It's quite easy to get a code for the gold version if you know who to ask.
    8P2 S3
    Jun 2007
    Cheshire
    95
    Quote Originally Posted by JohnS3 View Post
    Give it a try!
    thanks for that. I gave it a try but all the files seem to be in AAC format. When I go to the advanced menu the only option i get is create AAC version?
    StagsyA4
    Jun 2007
    Cheshire
    95
    p.s. I can't find the preferences section?
    StagsyA4
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Media Monkey supports AAC
    8P2 S3
