AH FabricationsSky Insurance
    Jan 2009
    11
    Cost to have coil packs replaced?
    Hello
    I have the 2.0fsi engine in my a3 and sometimes on cold mornings the car will judder, have done some research into this and it seems its directly related to faulty/worn out coil packs, it actually seems quite common in all the vag cars with the 2.0 fsi engine. Has anyone had this problem or knows hows much its going to cost me getting these replaced? The car is out of warrenty,(04 plate, 59k) so don't know wether to take it to a local garage because they can possibly do it cheaper. i will be very greatful for any replies!
    Lee
    Oct 2008
    Telford
    2,488
    They are between 20 and 30 quid each. I'd always get genuine ones and fit them yourself, they are dead easy!
    Your car sounds like only one might be failing, you need it hooking up to vag com to see which one but if they are on the way out its probably best to replace all 4.
    B6 1.8T Avant s line gmbh
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    when i got my s line from audi 2 days later it was jerkin like hell the engineer siad he gets this alot due to over spraying the engine clean but theres four of them coils and he only needed to replace one the computer told him which one after that it was fine ... not sure of the cost though i shouldnt imagin them to be to expensive though.. just phone up audi lancaster in manchester and get put through to parts they should tell you
    Quote Originally Posted by L3e123 View Post
    Hello
    Lee
    Jan 2009
    11
    Thanks for the quick reply guys, but is there a D.I.Y guide to show you how you change them? not really that competant to try it unless i've seen how its done!
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    If you do a search on here, there is a guide, it might be for the S3, but i think its the same.....
    Only about 30 each, and make sure you get the genuine ones from Audi, cant go wrong with them, bit more than copies, but worth it.
