JMB RetrofitsBadger5
Results 1 to 7 of 7
    K-Dash's Avatar
    Sep 2007
    Essex
    157
    Glovebox Broken?
    Hi,
    I have searched ASN but can't find much to help.
    My glovebox, when opened, drops very quickly which I guess is a problem with the spring mechanism.
    Has anyone else had this problem or is there a guide somewhere on how to remove the glovebox "hatch"? as I can't work it out.
    Many Thank yous'
    Audi A3 2.0 TDi Sport: Lava Grey
    • Bose Symphony II Sound System
    • Integral 6 CD Changer
    • Half Leather/Alcantara
    • Light package (Great!)
    • Parking Sensors
    • Eibach Sport Springs
    • OEM Sport Exhaust Tips
    • S-Line Spoiler
    • Genuine S-Line 18" Alloys
    • "OEM Style" Dension Ipod Dock
    FOR SALE
    NEW - BOXED - GENUINE - A3 HEADLIGHTS
    80 (the pair)
    SunnyDlite's Avatar
    Six speed Shimano
    Jun 2008
    161
    hey k-dash,
    if you want to remove your glovebox theres 7 bolts in total (or 2 bolts and 5 torx screws) to access them all you have to remove the side panel of the dash from the passenger side (the fusebox panel) and you will expose a bolt
    under the glovebox itself are 2 torx (or bolts sorry its been a while) on the body of the glovebox just after the opening of the hatch the other 4 are inside the glovebox
    opening the hatch run your fingers along the top lip where the hatch shuts for 3 torx/bolts and the final one is at the back just below the glovebox light (which i cant remember if it is necessary to remove but i remember taking it out)
    when you begin to take the glovebox out slowly lower it as you will have to detach the lights cable
    27,013
    Its the plastic clutch/mechanism on the left hand side of the glovebox has snapped, this basically is the plastic part that makes it open slowly, but check it 1st by removing the side plastic trim to the left of the glovebox that allows you to see with a small torch the whole assembly, its the side part that the door covers up when closed, just clips of the side easily, you can buy a new part for that, no need for new glovebox or repair as I did, works 100% since repaired, wont break again for sure, I superglued the parts back together 1st then epoxied round the joints so it was strengthened
    I actually also removed some of the glovebox squeaks at same time when I epoxied the glovebox seals which are coated in a kinda felt material where the glovebox parts are joined together in the parts you cant see when its in place, the seams did squeak a bit but epoxy holds them firm together so no movement thus no more squeaks, result
    K-Dash's Avatar
    Sep 2007
    Essex
    157
    Cheers guys.
    I will let you know how i get on.
    • Parking Sensors
    • S-Line Spoiler
    FOR SALE
    80 (the pair)
    Dec 2007
    52
    hey all, i have the exact same problem, the latch has snapped and when i went to the dealers, they said that i'd have to change the whole lid part (very expensive) so I'm looking for maybe a step by step guide as to what I can do to fix the latch myself, something like NHN has done...
    NHN, could you maybe give us a thorough guide as to what you used and what you did? Much appreciated mate.
    Dec 2007
    52
    anyone? NHN? thanks
    Wai-Fan's Avatar
    Jul 2008
    New York
    523
    Visit Wai-Fan's Instagram Channel
    Here's a removal guide for the glovebox from h5djr.
    http://homepage.ntlworld.com/h5djr/e...box-remove.pdf
    Found it in this thread.
    GloveBox
    A lot of people had the same problem including me. However, I took mine back to Audi to get it fixed FOC as I had warranty! Plus I probably would've broken it even more if I tried to fix it myself lol.
    2006/2008 - 52 Peugeot 206 1.4 LX, Platinum Silver
    2008 - 04 Audi A3 8P1 2.0 TDi (140) Sport, Mauritius Blue
    2013 - 2010 Audi B8 S4, Quartz Grey
