Hi guys
i've updated my RNS-E to 660 to get the sds working & have rewired the mis so that its wired to the inout of the RNS-E and the output on the RNS-E is wired to the input of the BT,
Now I tested the cable & it was worked but now that i've routed it behind the a-pillar and dash its not working. Vagcom is coming up with the following error on the telephone (77):
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 Q
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005275625
Coding: 0001222
Shop #: WSC 06314 000 00000
1 Fault Found:
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 232
Mileage: 24189 km
Time Indication: 0
Date: 2009.01.21
Time: 19:30:34
I've tested all 4 cables with a multimeter to make sure they havent split.
I'd appreciate it if someone could point me in the right direction as im pulling my hair out here. Thanks guys
Coding: 0001222
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 232
Mileage: 24189 km
Time Indication: 0
Date: 2009.01.21
Time: 19:30:34
