Chris NottVolks Autos
Results 1 to 20 of 20
    Dec 2008
    249
    a3 8p cruise control instructions & vagcom coding?
    Hi guys, managed to buy the cruise stalk & cover from local stealer and read my steering ECU to make sure it was he right one, which it was. Im going to have a bash @ installing this myself and wanted to know if anyone has any instructions as I heard the kits ordered from vagparts contained instructions. The only instructions i've managed to find on the web are for the A4 (not sure if its a similar install). The coding for vagcom wuld also be appreciated. Thanks in advance
    Dec 2008
    249
    All now sorted, thanks to help from VRStu, for info the coding needed for vagcom on 16 (Steering) after the physical fitting is:
    0004042
    The only digit I changed on mine was the 2nd to last digit - from a 1 (Board Computer, No Cruise Control) to a 4 (Board Computer, Cruise Control).
    After I did the following to login to the engine ECU:
    log in to engine 01
    select Coding II - 11
    enter 11463 in to the coding
    Hope this helps someone in a similar situation that I was in.
    Jan 2009
    27
    Was it easy enough to fit the stalk and cover?
    JohnS3's Avatar
    Oct 2004
    3,021
    It's quite easy, but you do have to remove the steering wheel.
    Dec 2008
    249
    Quote Originally Posted by Lunker View Post
    yeh easy enought, however have to remove ECU which can be tricky as the PCB can get easily damaged if your not careful. Once its out its just a case of unclicking the old Stalk and sliding on the new one.
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Just to point out you don't remove the ECU as in the Engine Control Unit, you need to remove the Steering Control Unit which is located on the steering column.
    Fizz - Juudging the fact that you mention not damaging the PCB leads me to believe that firstly you didn't get my reply to your PM in time last night and secondly you removed the Steering Controller by taking it apart which is very definately not the way to do it
    The 11463 login only applies to the TDi, S3 and TFSi will use long coding.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    26,762
    I 2nd that one, dont remove the bottom plastic of the steering module, you need to have a thin piece of metal to slide into a slot & push to side or up etc to make the tab loose so you can lower the front then rear you need to push in a tab with your finger to remove this module, removing trim 1st can break the contact pins & then you're well & truly fecked trust me as mine actually came of when I was pulling my module downwards purely accidental, luckily had another
    Dec 2008
    249
    Bloody hell looks like I was lucky then. I got the pic Stu but thought thats what it meant - as in take PCB out
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Yep it's a 2.3mm drill or similar you need, push that through the little hole in the front to release the front clip and then use your finger to release the other one from the rear.
    Stu.
    Dec 2008
    249
    Quote Originally Posted by VRStu View Post
    Aha now it makes sense. I guess I must have panicked seeing as I was due in at work in the morning and had a car without a steering wheel lol
    26,762
    Yeah funny enough I used a small drill bit aswell, lol, there's a knack to it but once done few times you'll be a pro, lol
    gynads's Avatar
    Oct 2009
    338
    Can someone help by getting all the info from their controller. I have coded it correctly, but as I fitted a controller from a US golf gti, I think i need to make changes to the other boxes ie workshop number etc? As such my DIS only has a few functions as before and my cruise has gone all wierd, still works but won't resume and us activated by pulling forward then down?
    I'd be very grateful
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by gynads View Post
    If you have installed a steering module with a reference starting 1K0 then that is the reason.
    When I fitted cc to my car it had a module 1K0 rev AF and worked the same as you describe.
    Pull towards to activate, flick down to set speed, flick up to increase speed, down to reduce speed.
    After braking or changing gear the cc dis-engages - to 'resume' just flick up again to re-engage and it continues to the previously set speed.
    When you push away from you to cancel you have to pull towards you again before you can reset.
    I think the only way to have the cc operate in accordance with the labels on the stalk is to fit a steering module beginning with 8P0 (midline) .
    gynads's Avatar
    Oct 2009
    338
    I'll put the old one back in then! (AH, came with car) cruise always worked fine, I bought a 1K0 953 549 AG to make my FBMFSW controls work,thinking I would work ok, think I'll put my old one back in and just fit the harness for now so at least it will light up
    Thanks again for your help mike
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,160
    Failed and now in search of help
    I tried and failed!!!
    Took the steering wheel and lower trim off without much probs.
    But could not take the steering ecu out.
    Any one got pics or info how to unclip what from where.
    Aslo does the clock spring mech need to be taken off to before the stalk removed?
    If so how's that done?
    Ta in advance
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by MrLapou View Post
    Ta in advance
    A little research before you started might have been a better idea !
    A search on this forum found this which you should have checked first:-
    Cruise Control Retrofit Guide
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,160
    Thanks for the the ticking off and link to very informative write up.
    Fossie
    Rhubarb Triangle
    3,961
    You're most welcome
    26,762
    If you get stuck, I'm up towards that area soon doing some installs, so could pop along & fit for you.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,160
    Thanks for the offer. What sort of timescale/cost would I be facing?
