Sky InsuranceEM Tuning
    Detector's Avatar
    Just waiting for the green light
    May 2007
    Midlands
    130
    Fog light bulb (front) removal help
    Hi guys, 3 weeks ago went through VERY deep water, did a first class impression of the Ark Royal followed by clutch slip and a fog light full of water (won't try that again).
    I'm going to remove the bulb and stick a 500w halogen work light in front of it to warm it through after draining water first, when fully dry pop the bulb back and it should be OK.
    Now, that very handy hand book has no mention of bulb changing anywhere can anyone help pls.
    Oh & Happy New Year to you all
    170 S.line manual
    Dec 2008
    Petersfield
    11
    hey, i've been looking in to this my self and all i could come across was this
    http://www.jmaguire.com/blog/2008/09/15/
    Its for an A4 avant but by the looks of it is the same as an A3 (im sure someone can confirm)
    hope it helps
    dave
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Its easy. In the black grill covering the fog light you will see two cutouts - one at the top and one at the bottom.
    You put a flat screwdriver or similar into these and squeeze together to release the plastic clips - and at the same time gently lever the black grill out from the opposite end to the actual fog light.
    The black grill just pops out when you release the clips.
    After that, the fog lights are held in by three torx screws which are exposed when the grill is removed.
    The foglight itself has a black plastic cover at the rear which then clicks off to reveal the bulb....
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
    Neil C's Avatar
    May 2007
    Grantham
    75
    If you've got to go to the trouble of removing everything, why not just put the whole fog like ( with the bulb removed ) into the airing cupboard. This should gently dry it out, and save having to use the work light.
    2004 (54) A3 Sportback TDi Sport Liquid Blue
