Volks AutosMonster Motorsport
Results 1 to 15 of 15
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Post How to: S3 exhaust flap mod
    Recy G sent me the link to the old thread about this mod:
    Exhaust Mod
    I knew nothing about it as I was away at the time but I thought I'd give it a go, so here it is.
    You will need:
    1x flat head screwdriver
    1x pliers
    about 50cm of thin locking-wire
    So here is the lever which moves the flap:
    And here is the flap inside the left pipe:
    Firstly you will need to use the screwdriver to pop the lever out of the hole in the actuator arm so it looks like this:
    As was pointed out by siu00adg (post #73) if you leave it like that the flap could quite easily close itself. More than likely the flap would turn around completely and end up about 170 degrees from the closed position (i.e. the flap nearly closed but facing the opposite way) and stay there.
    Not only this but the lever arm sits just where you would like the actuator arm to sit and would still be moving as normal so would push the actuator arm out of position.
    I decided I would use some .457mm locking wire to tackle the issue (I only had 2 sizes in the locker and the other was too thick):
    I tried a couple of ways of routing the wire to hold the actuator arm in place but this is how it ended up:
    I started by wrapping the wire through the hole in the arm a couple of times. I then put in a few twists to keep the wire secure. Then I looped both ends around the mount from the front to the back and then tied them off together against the first section of wire.
    You may find a better way to do this but the idea is there.
    The flap position is not perfectly flat but I would have thought it's free flowing enough anyway:
    I have not had a proper drive to try it out yet, only drove back from the workshop to my room, 1/2 mile at 20mph limit. I will be going out later to get some food so I will post results then.
    8P2 S3
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Interested to know how you get on with this.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    Khufu's Avatar
    West coast of Scotland
    5,693
    what's the issue with the flap? What does it do? Is it like the EXup valve on Yamaha motorbikes?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Well I'm back now, and I can't say I noticed any difference!
    Maybe a bit more popping on the overrun but that's it.
    8P2 S3
    FazS3's Avatar
    Apr 2008
    857
    Go out for a real blast then report back fella :P
    MTM THE ULTIMATE STAGE!
    Recy G's Avatar
    Nov 2008
    25
    Have got the NSN for that lock wire please Staz. Haha
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Quote Originally Posted by Recy G View Post
    ............ and the wire locking tool !!!
    Stu.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Lol you can have as much as you want when you come down mate!
    Quote Originally Posted by VRStu View Post
    It's so thin you don't need the tool. Or maybe that's because of my massive finger strength
    8P2 S3
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by staz1000 View Post
    and that' s another story....
    hatmeow's Avatar
    Turbo is the only way....
    Feb 2008
    247
    I guess this flap does will not exist if the exhaust was replaced with an aftermarket exhaust? What does this flap do anyways? Put up the back pressure during low RPM?
    A3 2.0T Sportback DSG.
    Engine / Trans:
    K04, Unitronic Stg II+ & DSG Stg II, S3 Injectors and Intercooler, APR F/Pump. BSH Intake, Forge DV, Oettinger Turbo Outlet, Eurojet throttle pipe, Milltek TBE. SP Meth Injection.
    Brakes and Suspension:
    Brembo 6 pot w/ 345mm slotted disks, TT front suspension, HPA Coliovers, OZ Palladio, 225/40/18 BS RE001
    Others:
    S3 Front, Pedals, & Mirrors, 09 SB Skirts & LED Rear Lights, Original HID retrofit, Oettinger Roof Spoiler. Defi Turbo Guage, FBMFSW
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Quote Originally Posted by JohnS3 View Post
    It certainly is!
    Quote Originally Posted by hatmeow View Post
    It won't be on an aftermarket no. I don't know what it does tbh. I don't know when it opens and closes but why would you want back pressure anyway? I thought back pressure was a bad thing as it retards power!
    8P2 S3
    JohnS3's Avatar
    Oct 2004
    3,021
    I thought it was to make the exhaust quiet at low revs and make more noise at high revs. Could be wrong though....
    Jun 2008
    194
    correct, the ideal situation on a turbo car is no back pressure at all hence 3" systems
    R8GGA
    Aug 2007
    Fulham
    451
    It certainly is!
    It's a drive-by noise EU regulation thing. Up to 3500 rpm; it keeps one side shut so the exhaust makes less noise; over 3500rpm the flap opens and the exhaust is slightly louder.
    Even my MGTF had one which I also overrode. (Oh dear yes I did just admit to having one of those at one point)
    awesome cars; both gone now though
    2004 Audi A3 3.2 Quattro S-Line DSG inAvus Silver, RNS-E Sat Nav, GSM, 18" RS4's, Bose, Tints
    2008 S3 3Dr, GIAC HAMMER, Phantom Black, RNS-E Sat Nav, GSM, FBMFSW, Optics, Privacy, Ipod, Rear Sensors, Armrest
    Weekend / Summer:
    2002 Ferrari 360 Modena, Nurburgring Silver, Bordeaux leather
    2006 BMW M6
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Quote Originally Posted by magnus911 View Post
    I see! I was listening out for extra noise at higher revs. Can't say I noticed a difference lower down either.
    8P2 S3
