Monster MotorsportChris Nott
Results 1 to 21 of 21
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Question/Advice/Help On Lowering...
    Hi all
    Most of you, probably seen i have new alloys on my car. But really need to lower it. I dont know any thing about lowering a car what brand to go for, how many mm i should go down by etc. As i dont want any rubbing issues. If some one could give me some advice Thanks
    Here some photo:
    Also Can i lower the front more then the back etc? Ride needs to be sitting right Thanks
    Ashley
    Dark Vader Half sibling - MyThread
    Jun 2008
    291
    I would go for coilovers pal, then you can set the height to just what you want front and rear. If you go for lowering springs you get what your given
    08 Ibis S3, REVO stg2+, APR HPFP, Milltek TBE, ITG intake, BSH catch can, H&R springs, 19" MTM's, Lamin-x'd
    ???bhp, ???ft/lbs
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Coilovers yes. If you got a spare 1k, free fitting on KW V3s from AMD I believe.
    Jun 2008
    291
    The KW v3's are mint but quite expensive, I ran eibach PPS on my mk5 Golf GTi and they were brilliant for the money about 600quid I think, better ride and comfort than std. Sayin that by the time you've paid for fitting your gettin near the KW money
    ???bhp, ???ft/lbs
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Hi thanks for the reply 'JustCharlie' & 'N8KOW'.
    Coilovers would be best but right now i dont have a spare 1k probably wont in till around july or june. Any other ideas? Or can i get Coilovers for a lower price?
    Ashley
    27,096
    Urrrm yours isnt quattro is it Ash cause I have 30mm eibach pro's for quattro 4 weeks old, that would drop them lovely
    Also where are those rs6 wheels?
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Simplest and cheapest for looks only will be swap the springs out for something like the Eibach but it won't do anything much for your handling and may cause the OEM dampers to wear more quickly.
    Next up is to change for some shorter reach stiffer dampers to compliment the springs, there are several options available.
    A good combo of ride height and handling as well as good for everyday driving without doing your back in would be the Koni FSD combined with the Eibach spring.
    Coilovers will give you adjustable ride height but do come and a price and judging by your comments probably a price you can't really afford.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Also if buying used make sure you buy the right setup - For a TDi you need TDi springs as the nose weight is greater.
    How about a set of OEM sport stuff from an S-Line or something that someone has removed.
    Stu.
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    The s-line stuff would be pretty good going to have to look around now
    Ashley
    Quote Originally Posted by VRStu View Post
    Hi Stu thanks for that mate. So far the Koni FSD combined with the Eibach spring. looking good a one. Where can i buy them? Know how much they actually cost.
    Hi
    Nope not a quattro otherwise would have them. The Rs6 Alloys are in my Shed.
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    The FSD's etc aren't cheap. I always use JKM but there are plenty of Koni/Eibach dealers around.
    370 + VAT for the FSD's - http://www.jkm.org.uk/performance/suspensionaudi.htm
    125 + VAT for the Eibachs - http://www.jkm.org.uk/performance/eibachaudi.htm
    I've had 2 cars with FSD's now and they are excellent.
    Stu.
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    A few guys on the Golf forum have tried Jamex coilies and they're not too bad. On the mk5, they weren't that hard a ride and didnt handle all to bad.
    I think they are about 300ish with 1 years gurantee...
    http://cgi.ebay.co.uk/Jamex-Coilover...1%7C240%3A1318
    I'm sure a 50mm drop will be good enough..
    it may be worth researching into these but i was actually going to buy a set of jamex for my previous golf (But a branded set came up cheap so i bought them!)
    Has anyone else used these ?
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    kaz219's Avatar
    Jun 2008
    1,796
    These guys say they're pretty good:
    http://uk-mkivs.net/forums/p/94156/672127.aspx#672127
    I think they could be good coilies for people on a budget ...
    Vagcom'd too
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Alright Kaz...Nice one for looking that up for me. Yeah had a good look over the Golf Forum few people seem to have them and that Jamex Coilies seem to be getting good feedback for the price they are at. Will do a bit more research thanks for that. How much you reckon i should drop the front and the back? As i dont want any rubbing issues or any thing. much appreciated ashley
    Quote Originally Posted by kaz219 View Post
    Nice one for that Stu for the price dont look to bad. And seeing you had them on both of your cars must be pretty good. How the car handling and every thing after they were fitted? much appreciated ashley
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    The main thing with the FSD's and the reason they are more expensive than other shock absorbers is the technology they use - Frequency Selective Damping (FSD).
    http://www.koni.com/190.html
    It gives you the best of both worlds - tight handling when you need it but without the bone shaking normally associated with lowered/stiffened suspension.
    Stu.
    kaz219's Avatar
    Jun 2008
    1,796
    Janspeed or soemthing like that are a uk supplier of them and they give guaratees - If you were thinking Jamex, may be worth contacting them :D
    Vagcom'd too
    27,096
    Ash just give Damian a shout at dpm, I got my fsd's from there, very helpful indeed Ash, recommend anyday & he does many different suspension kits/setups
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    COILOVERSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS SSSSSSS
    Oct 2008
    133
    Sorry for jumping in on this thread but Im also interested in lowering my 1.9tdi sport 05 Sportback and was wondering if anybody can answer my question.
    I only want to buy springs and have looked at Eibach but theres one thing bothering me. On JKM website (link posted earlier) there is no distinction between SE, Sport, or S-line. By my crude measurement the SE models are at least 30mm higher than my Sport and a workmates Sportback 2.0tdi S-line is approx 10mm lower than mine.
    The Sportback application for my category (1.9TDI) is -30mm but has anybody a clue what thats based on given it also includes petrol cars that could be SEs??
    <<1.4 TFSI, 1.6 automatic gear box, 2.0 FSI, 1.9 TDI (CODE: E10-15-007-06-22)>>
    Sorry if Im missing something but im confused?
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Thanks for that Kaz will contact them
    Nigel thanks for that mate. Have Pm Daminan to see what he can do. Thanks
    Oct 2008
    Telford
    2,488
    Quote Originally Posted by Paul_c View Post
    Yeah the springs height reductions are based on the standard model height in all cases. If i bought -30mm springs for my S line chances are it might actually higher it!
    B6 1.8T Avant s line gmbh
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Hi Paul i would contact them and then maybe they can tell you which product would be best for your Sportsback Sport. My SE is a Petrol
