Part Number Check :)
edition
NULL
Hi,
Wondering if someone could look up a part number for me please.
1K0 615 601 L Will that fit a 3.2 a3?
Cheers,
Well it appears to be a front brake disc - 260 x 12mm 5x112 PCD
Whether it's suitable for a 3.2 A3 is another matter. Audi code the front brake systems on the various A3s using what they call PR codes. The codes for the front brakes are codes 1LJ, 1LK, 1ZD to 1ZP. The code for a particular vehicle is shown on the Vehicle Indentification Sticker which can be found in the front of the Service Book or under the floor covering in the luggage compartment. On my particular A3 it's the code is 1LJ and is the 3rd item on the 8th row from the top of the sticker. This code gives the size of the brake disc required for each vehicle type.
Let me know the code and I will be able to tell you the size Audi specifiy.
if it has the 345mm discs then no -
the part no for a 345x30 disc, 5/112 is 1K0 615 301 M (thats an R32 VW part no) but should do the biz!
AFAIK, the 3.2 A3 8P has the bigger calipers (same as S3/R32/LCR)
11
858
314
708
559
