EM TuningAH Fabrications
Results 1 to 22 of 22
    a3guy's Avatar
    Jul 2006
    204
    car not starting
    drove through a massive puddle tonight , and about a mile from home the engine stalls and the glow plug light flashes.
    manage to start it up again and manage to get back , but vagcom throws up this error .
    Control Module Part Number: 03G 906 016 DT
    Component and/or Version: R4 2,0L EDC G000AG 5878
    Software Coding: 0000078
    Work Shop Code: WSC 06314
    1 Fault Found:
    16706 - Engine Speed Sensor (G28): No Signal
    P0322 - 000 - -
    i assume it has got wet and is not working correctly , does anyone know where it is located and can it be cleaned etc ?
    A3-SLINE 2.0 TDI DSG , phantom black,full leather, cruise control, heated seats, RNS-E audi navigation, bose, auto dipping wing mirrors, interior light pack, auto rain sensors and dipping mirror.
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    If you say the globe plug light came on, Id start by changing the globe plugs.
    it is possible that the car started last night as the car was warm and as the cars cold now, it will be harder to start. The globe plugs might not get as hot as they should to ignite the fuel.
    They're not that expensive and i've been told they're not too hard to do.
    Thats what i would do (but i may be wrong!)
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    I wouldn't think it the glow plugs.
    Almost certainly the sensor you mention.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    I've uploaded some images for you -
    Item 10 is the location of the G28 Hall Sender -
    Item 1 is the Hall Sender -
    Stu.
    a3guy's Avatar
    Jul 2006
    204
    excellent cheers
    have found a guide too , although i imagine the location would be slightly different.
    http://audizine.com/forum/showthread.php?t=104097
    god knows where i can get the part on a sunday from
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Probably worth taking the plug off and drying it out. I wouldn't think the water would ruin the sensor.
    Stu.
    a3guy's Avatar
    Jul 2006
    204
    the g28 sensor has been replaced and the fault is still there , anyone got any ideas ?
    kaz219's Avatar
    Jun 2008
    1,796
    Have you checked all the fuses as something might have tripped?
    Vagcom'd too
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Do you still have the fault code? I've had a look at some CFD's and it seems to me that the G28 power is derived from the ECU. There is a ground which might be worth checking.
    Stu.
    a3guy's Avatar
    Jul 2006
    204
    just to update this, have been advised the fault could be with the phonic wheel not sending the pulse to the ecu.
    anyone know of any competative audi technicans i can get the car towed to ?
    based in surrey
    not looking forward to the bill with this just before christmas
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    I think the G28 is what's being reffered to as the Phonic wheel.
    Stu.
    a3guy's Avatar
    Jul 2006
    204
    Quote Originally Posted by VRStu View Post
    thats strange because the guy said the gearbox needed to come out to check the phonic wheel ?
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    I have some TDi publications here and the engine speed sensor is the G28 which is indicated in the pictures above and you say has been changed.
    Phonic wheels are used to determine speed and position which is exactly what the G28 does although in the case of the G28 it's a Hall Sender.
    The only reason I could see to remove the gearbox is to check the condition of the sender wheel.
    Stu.
    a3guy's Avatar
    Jul 2006
    204
    ah right , so i think he means the hall sender the actual wheel then
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    As you can see from the diagram the wheel is a solid part without any connections etc. Pretty much just magnetic so difficult to see how it would fail but may be dirty.
    When you changed the G28 would there be enough room to get something such as a small cloth or cotton bud or similar in? If so, and so save removing the box, if it is just dirty I would suggest getting someone to help you roll the car in gear whilst trying to clean the wheel.
    Doh - Just notice you have DSG. A little painfull but maybe you could clean some of it by starting and then stopping the engine hoping it stops in different places.
    Next up from that I'd want to be line checking the wires up to the ECU. Are you sure the plug is clean and dry?
    Stu.
    a3guy's Avatar
    Jul 2006
    204
    i should of been clearer first , i have had a audi technician looking at the car.
    the g28 was replaced and it made no difference, he has tested the wires i believe and had found that there is no pulse on the signal wire.
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Was it a new G28?
    Stu.
    a3guy's Avatar
    Jul 2006
    204
    yep
    a3guy's Avatar
    Jul 2006
    204
    seems christams came a bit late this year , turned the car over this morning and it started first time.
    Thought it may have been a fluke but did the same for 4 more tries and it runs fine now, did a 10 mile run just to get the engine upto 90c and it is perfect, very strange.
    something else must of got wet that has dried out.
    Khufu's Avatar
    West coast of Scotland
    5,693
    Glad its going!!!
    kaz219's Avatar
    Jun 2008
    1,796
    Good to hear its running - i think something must have died out too!
    Vagcom'd too
    Cali's Avatar
    Jul 2004
    North West
    134
    Lucky escape - glad it dried out and is working fine now - phew
    A3 TDI SLine Quattro
    OEM + Rubber mats & ASN stickers
