Badger5Monster Motorsport
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,969
    Does the A3 have gearbox issue's or any other ?
    Im looking in to buying the A3 TDI SPORT (53-55 plate) and was wondering if there had been any issues with the gearbox?
    I know the older models upto 2001/2 had problems with the gearbox's packing in ,so was a bit curious.
    What other issues should i look out for ? i.e common faults etc.
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    AFAIK, the gearbox is not a common prob on the A3 8P.
    I've heard of 1 DSG gearbox going wrong but a software update from Audi sorted it.
    Common faults are the IMF (Intke manifold flap), it jams and needs to be changed (Around 300 parts and labour private garage but you could do it yourself).
    the wheel bearings (my car was done at 38k and been fine since)
    and there is the common prob with the head. If the car drinks coolant fluid, it may need a new head which will cost a bomb.
    Thats about it TBH but if you get a fully serviced one with average miles, you should be good :D
    HTH
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    vw754's Avatar
    Nov 2006
    U.K
    1,969
    nice one for that helpful info, i probably be bying one with around 90+k miles so best check for coolant loss first.......a challenge when buying privatley!
    kaz219's Avatar
    Jun 2008
    1,796
    here's the post i started just before i bought mine
    Buying a A3 TDI 2.0 - Common Faults?
    HTH
    Vagcom'd too
    Slipp Digby's Avatar
    Oct 2008
    73
    Quote Originally Posted by kaz219 View Post
    The IMF went on my 54 plate TDi sport as well and was replaced by the dealer (it was a used approved).
    I also had to have the flywheel and clutch replaced under warranty at 35000 miles. Probably a one off but, do a hill start when you test drive and listen out for low pitch vibrations.
