Badger5Monster Motorsport
Results 1 to 12 of 12
    Dec 2008
    11
    2.0 TDI DSG Shuddering / Juddering!! HELP!!
    Hi, Firstly, i've got to say what a brilliant forum! Been reading this forum for ages but this is my first post, so be easy!
    I'm having huge problems with my A3 SB 2.0 TDI DSG, I hope some one will be able to shed some light on it....
    I'm getting this horrible shuddering/juddering (like the engine's about to stall) when I'm in 5th or 6th gear. The revs have to be low, say 40mph in 5th or 6th gear and then when I use some low to medium acceleration the car jumps around like crazy! It sounds like the engine mounts are about to be ripped off! The problem disappears if you put your foot down and accelerate hard. A constant vibration can also be felt when at high speed...like 80mph. Its like the car's stuttering but very minutely. All this only happens once the engine has warmed up.
    Gone to an Audi specialist....stuck it on VAG-COM....no problems thrown up, the guy spent the day looking at the car and was stumped! Also taken it to 2 other garages with no answers.
    I don't particularly fancy getting robbed up by Audi at the moment so any help will be much appreciated!!
    Thank you!!!!!!!!!!!!!
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Hmm, I would think it has all the syomptoms of a DMF issue.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    Dec 2008
    11
    Forgive me.....whats DMF??
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    dual mass flywheel, it takes out the vibrations ... however they don't always last that long.
    Gone A3 TDi S Line DSG Bluefined
    Now Seat Leon Cupra about to be Bluefined
    Dec 2008
    11
    So is this something expensive to fix? Could the problem be anything else? Been hearing horror stories about cars with same sort of symptoms and Audi just changing the gearbox at horrendous cost!
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    It can be expensive to fix mainly due to labour. The parts are currently quite cheap from VAG, probably due to commonality of the failures.
    Normally the clutch and DMF are replaced together.
    Stu.
    Sep 2006
    Surrey
    1,224
    700-900 inc. labour + parts
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Depending on a few factors you may be able to ask Audi for a contribution.
    Firstly it is a common failure so you could certainly argue that point.
    You will be better placed if you have a full Audi history.
    Stu.
    Jun 2008
    24
    similar symptons i was thinking it was the DSG but it makes sense to be the fly wheel....
    Is there anyway you can tell if its the flywheel besides symptons on hows the cars acting. Can you check the fly wheel visually without have to dissemble anything major ?
    Thanks a lot
    Dec 2008
    11
    Hi, thanks for your responses!
    Just got off the phone to my local Audi specialist and told him that I have been doing some research about the problem and that a lot of people seem to think it's the DMF.
    He then told me "I dont know what your talking about, no automatic in the world has a Dual Mass Flywheel", I ended the conversation feeling a bit embarrassed!
    Anyway, Is this true? Does the DSG Audi A3 not have a flywheel? Can any one verify this?
    Thanks!
    Joe
    Sep 2008
    London
    50
    Your car dose have a flywheel, but not a the you have being discussing .....and if it helps it is the flywheel hat is making your car do that and the dealers are in the know about it...i know this because i have a friend who works at Audi & VW and many car have had the same problem
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    You shouldn't feel embarrased, you should find another specialist though - perhaps one that knows what he's talking about.
    Stu.
