EM TuningBadger5
Results 1 to 9 of 9
Thread: break light
    jonnysimm's Avatar
    jonnysimm
    Nov 2008
    warrington
    160
    break light
    Does any one have any ideas why my break light stays on when i turn my light on?? and the warning light comes on which means there is a fault in the rear break light and it comes on every time i break VERY ANNOYGING. if any one can help thanks.
    jonnysimm's Avatar
    jonnysimm
    Nov 2008
    warrington
    160
    do you know where the switch is ?? is it hard to get to the wires under the stearing wheel because it might just be a faulty wire round there do you think ??
    edition's Avatar
    Nov 2007
    1,417
    BRAKES
    jonnysimm's Avatar
    jonnysimm
    Nov 2008
    warrington
    160
    wot ?
    The brake (as opposed to break) light switch is mounted on the foot-pedal assemble in front of the brake pedal. As the brake pedal is pushed it allows the switch plunger to spring outwards, thus switching on the brake lights. Check that this happens when the brake pedal is pushed. If it does then the fault is either with the switch contacts or the wiring. This is assuming that the brake light bulbs are in order.
    Dave R (h5djr)
    jonnysimm's Avatar
    jonnysimm
    Nov 2008
    warrington
    160
    thanks fella ill i had look b4 but couldnt see out. but ill have a other look when there is light.
    Mar 2008
    North East, UK
    91
    Try checking that the bulbs are not blown, and are seated properly and not corroded or damp in the light cluster.
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    What light are you switching on that also activates the brake lights?
    Have you got LED's or anything silly like that fitted?
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    jonnysimm's Avatar
    jonnysimm
    Nov 2008
    warrington
    160
    i have the LED'S butjust the standard one at the top of the boot. and they come on when i my put side lights on and normal lights?? the warning noise is what pissies me off the most dont wanna drive my car its that bad. lol
