Sky InsuranceChris Nott
Results 1 to 7 of 7
    Jul 2007
    130
    How to Remove Outer Case of S3 Mirrors
    Thinking of painting the mirrors of my new S3 in Sprint Blue...not too keen on the silver finish.
    Is it easy to remove the casing? Or strictly a job for a dealer?
    S3 Sportback DSG in Sprint Blue with mag ride, interior lights, Bose, parking sensors.
    and...
    99 TT Roadster
    26,762
    its a little pain in rear but can be done, I find it easier to remove the glass tbh, remove glass by angling the mirror downwards so there is a gap at the top, get a thin wide piece of wood or something to wedge into the gap & make sure its in the middle of the glass just above the directional motor, then slowly put pressure its the glass is being forced outwards towards the door & at same time get your fingers in there to assist, it should slowly pop of, dont rush take time.
    Then undo the 2 scews underneath that holds the bottom black cap on, this is tricky to get of but pushing from the top inside the housing releases the cap downwards, then the actual mirror cover usually has 1 screw fixed in the rear, so unsrew this & there are 2 clips kinda hidden at the rear that need a very subtle move to the side or outwards to release the cover from underneath, you need to do each side a bit at a time then it comes of loosely to be able to remove completely from the mirror stalk etc then reverse but dont paint your silver ones.
    But if you're in a rush forget it as it takes a fair while overall trust me, not a quick job
    JohnS3's Avatar
    Oct 2004
    3,021
    Mmmm, is it wise to be posting that info on a public forum bearing in mind the number of mirror covers that are being stolen? A PM would have been better.
    26,762
    Never known a mirror thief to remove them so caringly, lol
    Jul 2007
    130
    Thanks for the info..and the advice not to do it!!
    I haven't yet made a final decision....I might get to like the silver ones, but at the moment I reckon a proper colour match would be better.
    and...
    99 TT Roadster
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    If your thinking of changing the colour i would buy another set from a breakers or ebay and get them sprayed and then you can keep your if you decide to change
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
    Mar 2008
    Its really not all too difficult to do, but time and patience is needed. NHN is pretty much on point about how to do it. Don't forget to remove the wires from the mirrors (not sure if you have heated or not).
    Also, do as mattandrew suggested and get some used ones and spray them...don't mess up your good ones.
