Monster MotorsportBadger5
Results 1 to 16 of 16
    KRL
    KRL's Avatar
    Jul 2007
    523
    2.0 TFSI HPFP Cam Lobe and Cam Follower
    Hi All,
    I would like to know if anybody here has suffered Cam Follower failure/wear and subsequent Cam Lobe failure/wear. On the VWvortex forums this topic has been discussed in a lot of detail:
    http://forums.vwvortex.com/zerothread?id=3750088&page=1
    I am a little concerned about the potential affects of this problem seeing as it has been seen on stock cars as well as modified and my car is about to go out of warranty.
    Do you 2.0 TFSI owners check your Cam Follower and Cam Lobe regularly for this? Also does anybody know if this is checked by Audi UK as part of regualr servicing?
    There was a TSB released by Audi US for this problem:
    http://livall.kicks-ass.net/20t_cam_...t_cam_wear.pdf
    So my questions are:
    1. Does this affect UK model 2.0 TFSIs and is the above TSB relevant for the UK?
    2. Do Audi UK check for this?
    3. Has anybody with aftermarket HPFPs suffered problems?
    4. Has anybody on stock HPFP suffered problems?
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    Oct 2008
    888
    This was addressed, as you pointed out, by Audi. l havent heard of any recent problems. l will be speaking to my garage about checking as part of a service
    KRL
    KRL's Avatar
    Jul 2007
    523
    Quote Originally Posted by dc240969 View Post
    How was it addressed and was it addressed in the UK?
    Oct 2008
    888
    The material that the cam was made from was softer than the material on the pump, hence wear. The OEM pump would have worn the cam as well.
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    I ran a replacement pump without issues. I did do regular checks at 7k ish intervals and also replaced the cam follower (20) each time. No problems for me.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    KRL
    KRL's Avatar
    Jul 2007
    523
    Yes but there was no recall for this problem as far as I am aware it was only a TSB. Therefore if you have an earlier 2.0 TFSI (mine was manufactured on 23.07.06) I am concerned this problem could still effect me and others. My car has 56k miles on it at the moment so will soon be over the 60k warranty mileage and a replacement cam would be quite a financial hit.
    KRL
    KRL's Avatar
    Jul 2007
    523
    Quote Originally Posted by VRStu View Post
    Thanks. Was the cam follower worn each time or did you replace more out of preventative maintenance?
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Preventative, for the sake of 20 I thought it was acceptable.
    Stu.
    PW-Motorsport's Avatar
    Jun 2006
    Pembrokeshire
    389
    There are some well documented Cam wear problems with other VAG engines.
    1.9 150hp TDI PD
    S4 and RS4 V6
    First two that spring to mind
    KRL
    KRL's Avatar
    Jul 2007
    523
    Seems to be quite a wide spread VAG issue then.
    Here is a summary of how I understand the problem on 2.0 TFSIs:
    Your Cam Follower will wear in time as it is made of a softer material than the Cam. Therefore you need to periodically check the condition of your Cam Follower (I intend to check mine asap).
    If your Cam Follower fails it is likely that the HPFP will do some damage to the Cam as it will be coming into direct contact with the Cam surface.
    There are 2 variations of the 200 ps 2.0 TFSI Cams - A variant and B variant which both have 3 lobes. It seems to be a bit of a lottery which Cam people will have (it does not seem to be tied down age). The A variant Cams are one piece while the B variant Cams are two piece. Cam failure seems to be more likely on the A variant Cam.
    The S3 2.0 TFSI has a 4 lobe Cam and I am not sure if this problem effects the S3?
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by PW-Motorsport View Post
    1.9 150hp TDI PD
    S4 and RS4 V6
    I thought the issue on the PD engines (not just the 150) was due to the wrong oil being used?
    Khufu's Avatar
    West coast of Scotland
    5,693
    is this confined to the TFSi engine or is there a chance on my 2003 N/A FSi engine? It's only done 22k so far but is it something i can prevent or delay the onset?
    aiculedtzu's Avatar
    under pressure
    Oct 2006
    Romania
    208
    First i had a KMD Pump which failed after 2.000 miles (found some petrol in the engine oil, not very good :-) Now i'm running with an APR pump which works great so far.
    I've changed the cam follower at 30.000 km and it looked like new. The same applies for the cam lobe. I think the Motul 300v oil that i use is responsible for this :-)
    Audi S3 2.0 TFSI quattro - Turbo-Back exhaust - Cold Air Intake - Uprated Fuel Pump - Upgraded Clutch - Upgraded Intercooler - Stage2+ Software
    KRL
    KRL's Avatar
    Jul 2007
    523
    Quote Originally Posted by Khufu View Post
    Sorry I'm not sure about the 2.0 FSI engine. Does it have a HPFP?
    KRL
    KRL's Avatar
    Jul 2007
    523
    Quote Originally Posted by aiculedtzu View Post
    Interesting! How often do you change your oil?
    aiculedtzu's Avatar
    under pressure
    Oct 2006
    Romania
    208
    ~ 5000 miles.
