Sky InsuranceJMB Retrofits
Page 2 of 5 FirstFirst 12345 LastLast
Results 41 to 80 of 186
  1. #41
    Jamiekip's Avatar
    Jan 2009
    710
    Quote Originally Posted by mac1403 View Post
    There are loads for sale on Ebay, but they are mostly from Hong Kong or the States. The main problem I found was refractor style led's are wider due to their design than the standard wedge festoon bulb. This gives you a real headache when you try to fit them. So to get them all the way in you have to bend the contacts. I have done all mine now except the puddle and boot led. These are doing my head in and I can't get answers to anything from anyone on here who has done the whole thing. Must be on the ignore list LOL
    You should try PM'ing Marc in here:
    http://www.vagoc.co.uk/vb/forumdisplay.php?f=14
  3. #42
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I have done the puddle ones, as above, didn't have any problems with them. also didn't have to bend any contacts.
    What problems are you having?
    8P2 S3
  4. #43
    mac1403's Avatar
    Sep 2005
    wales uk
    956
    Staz. Where did you get the refractor led's from. The puddle lights are narrower than the footwell lights so when I try to fit the refractor wedge they will not fit properly as the contacts are shaped to hold the standard wedge festoon. The other problem I have is when I try to replace the boot bulb with an led it will not light at all. Fitted a 150 Ohm resistor and it comes on flickers and goes off again. Also tried it with a 220 Ohm resistor and it was the same. Should I have fitted the led's in the puddle lights first? as the above problem is with the puddle lights standard and trying to fit the boot led first.
    Facelift S3, Sprint Blue, Bucket seats, Sunroof, Sat Nav, Bose, Elect Mirrors, Light and Rain, Interior Light pack, Flat Tyre Warning, GSM Phone Prep, Led upgrade, Illuminated speaker grills.
  5. #44
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I got all the bulbs via the links Toby posted above. I used the same flank bulbs for the footwells as I did for the puddle lights. Exactly like these. I used 2x 220Ω resistors, one in each side.
    The boot light and footwells are on different circuits so they won't affect each other.
    I haven't done the boot light as I didn't see the point but as the combined resistance for the 2 footwell LEDs is 108Ω I would try a 100/110Ω on it's own for the boot mate.
    8P2 S3
  6. #45
    mac1403's Avatar
    Sep 2005
    wales uk
    956
    Thanks mate. Thats shed a bit of light on the matter. I will order some of the leds you mentioned. I have been using the ones with the 4 leds spaced around and 1 on the end. They are too wide for the bulb holder which is why I have been having problems. Do you get good enough light out of them for the puddle lights?
  7. #46
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Aha no these ones are just a bit of 1mm board with the LED soldered on, fit in nicely!
    The light from them isn't more than the bulbs they replace, it's just white. They don't need to be any brighter anyway!
    8P2 S3
  8. #47
    Mar 2009
    Staffordshire
    1,247
    Excellent tutorial thanks. I'll give this a go for the rear number plate bulbs as I have really wanted to do this for a while. Does anyone know if 37mm bulbs will fit? I always order LED bulbs from www.ultraleds.com as I have had problems with cheap LED bulbs off eBay.
  9. #48
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by scott1andrews View Post
    37s will fit no problems mate.
    8P2 S3
  10. #49
    Mar 2009
    Staffordshire
    1,247
    Quote Originally Posted by staz1000 View Post
    Thanks mate, I'll let you know how I get on. I may attempt some others in the future too!
  11. #50
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    Add martyboy on Facebook
    excuse my ignorance, but i see you have to solder only one 150 ohm resistor in parallel for the rear interior lights when replacing with led bulbs, but what about the front festoon light?
    mine is the basic one with only the one main light,
    so do i need to solder a 150 ohm resistor in parallel with one bulb, two bulbs or no resistors?
    cheers
    Just taken delivery of my Glacier White S-Line Sportback
  12. #51
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    I really need to do this mod!
  13. #52
    mac1403's Avatar
    Sep 2005
    wales uk
    956
    Quote Originally Posted by martyboy View Post
    cheers
    If you don't have the map reading lights and just have the main light you shouldn't require any resistors. The only reason you have to fit resistors in the rear map lights is to prevent them staying on dim when you are driving. The only other resistor is required for the footwell lights as they will only stay on for 5 seconds if you don't fit one
  14. #53
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    thanks for clearing that up matey!
    wasnt sure after reading about the issues with 'bulb-out' warnings on the DIS
    as the led's dont draw as much current as the old bulbs. i thought resistors had to be added to all the led replacements for this reason!
    cheers
  15. #54
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I didn't fit a resistor for the map reading lights by the way and don't have the dim bulb problem.
    8P2 S3
  16. #55
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    and i assume no bulb-out warnings either on the DIS?
  17. #56
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    No mate. Or errors with VCDS.
    8P2 S3
  18. #57
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    fitted my leds to the front and rear interior lights today, and no probs with rear lights staying on dim or bulb out warnings on the dis! so all in all pretty chuffed!
    now does anyone know if changing the glove box light is just as easy, old bulb out, new led bulb in!!!
  19. #58
    gixxer600k4's Avatar
    Feb 2009
    hampshire - UK
    686
    it should be like that with every bulb in car, obviously you may need to wire up some resistors, but should be fine! i think the glove box and boot light are the same bulbs you have in ur side lights
  20. #59
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Someone was asking about this the other day, they thought the glove box was on the same circuit as something else as they were getting a warning. I can't remember who or where though!
    There's only one way to find out for sure though.....!
    8P2 S3
  21. #60
    mac1403's Avatar
    Sep 2005
    wales uk
    956
    That was me mate. Wasn't the glove box, it was the boot though. I thought the boot and door puddle lights were on the same circuit. Have now done all the lights with led's except the boot. Only actually used one resistor and that was for the footwell lights (150Ω in one side)
  22. #61
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Aha yes! Sorry I forgot.
    So you don't need one in the glove box then? And is it the same as a sidelight bulb?
    8P2 S3
  23. #62
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    if it is the same, what are the sidelight bulbs?
  24. #63
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Normal 5W5s mate:
    8P2 S3
  25. #64
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    could someone clear this up please, do the resistors need to be in parallel or series?
    ive just been told of some smart arse at work they need to be in series, but i thought parallel?
  26. #65
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Parallel mate! If you put them in series the voltage would be dropped across the resistor and not the LED.
    8P2 S3
  27. #66
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    its not often im wrong, but im right again!!!
  28. #67
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    It's not the first time I've had to help out one of your kind with some basic electrics
    8P2 S3
  29. #68
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    electrics? what are they?
    here is what this guy is quoting, help me prove him wrong, PLEASE?
    "Every commercial led light made has a current limiting resistor. To figure yours add the forward voltage, subtract from 12 (for 12 v system) and divide by .02 (20ma). This is simple Ohms law. For 3 super-bright leds there is a 10.2 forward voltage drop (series wiring). So 1.8/.02 gives a resistor of 90 ohms. For 13.8 volt supply a 3.6/.02=180 ohms. Super-flux leds are slightly higher voltage so 3.6(typical) is used for each led. For 2 on a 9v battery it is 1.8/.02=90 ohms. If you don't have the exact value, always go to the next higher fixed resistor. This will work fine w 100 ohm resistor or even higher, and gives a small margin for safety. For questions consult ohms law............."
    he is a tosser by the way!!!
  30. #69
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Easy to prove him wrong... the LEDs we're talking about already have the resistors built into the circuit to enable them to work with an input voltage of 12v.
    All we're trying to do with the parallel resistor is fool the car into thinking there's a normal bulb there as the current draw on the LEDs isn't enough and the car things the bulb has blown. It then kills the power to the LED.
    For questions consult STFU law.......
    8P2 S3
  31. #70
    mac1403's Avatar
    Sep 2005
    wales uk
    956
    OMG.....Does he do the vulcan salute and speak Klingon. I hate pointy headed people LOL
  32. #71
    warren_S5's Avatar
    Oct 2007
    7,166
    Being somewhat indolent, and lacking in technical capability, can I (at any cost) buy a PIAA extreme white bulb that will look like the OEM ones, but deliver the super white light (OK, so not LED white).
    I can't be @r$ed with soldering resistors and all that malarky despite it looking VERY trick.
    Been searching t'internet and found some smoked festoon bulbs (12v 5w 42mm 264 type), but not upgrade ultrabright ones.
    Also, does anyone have a part number for the reading lights in the overhead festoon? I was hoping they were going to be like the w5w's that go in the side lights (as I have a spare set of PIAA extreme's sat in the garage), but they're not
    Audi S5 3.0V6T Coupe Black Edition
  33. #72
    Jul 2009
    London
    41
    "All we're trying to do with the parallel resistor is fool the car into thinking there's a normal bulb there as the current draw on the LEDs isn't enough and the car things the bulb has blown. It then kills the power to the LED.
    For questions consult STFU law......."
    Epic
  34. #73
    Jul 2009
    London
    41
    If i didn't opt for the interior lighting extra for my car, will i still be able to do this modification? I understand that the puddle and footwell lights won't be there (is this correct?) but does that mean that the bulbs won't be fitted? or that i would have to cut holes and buy the light cases as well.
    Cheers for the help
  35. #74
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    There's some info in the FAQs thread about interior lights retrofit.
    8P2 S3
  36. #75
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    What a nightmare this all seems!
    I have done this in my BM, and all I had to do was fit resistors to the numberplate lights, the interior ones worked without fault or resistors.
    I mean who need bulb failure warnings on an interior bulb FFS? You can see when its blown just as easily as you can see the warning notification, in fact you'd know as soon as you opened the door, before the ignition was even on, talk about over engineered... d'oh!
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
  37. #76
    G"MAN's Avatar
    GONE LOW BUT GOING LOWER
    Jul 2009
    MILTON KEYNES
    82
    would this mod work with the single led bulbs you can get from like maplins or any electronics store.. ??
    G
  38. #77
    Mar 2009
    Staffordshire
    1,247
    Quote Originally Posted by G"MAN View Post
    G
    I'm sure you could probably to get it to "work" with enough effort but would it look good? no, probably not - you need proper fitment bulbs really which send light in the right directions.
  39. #78
    G"MAN's Avatar
    Jul 2009
    MILTON KEYNES
    82
    umm ok then i will have a look anyway see what it looks like and will let ya know..
    thanks buddy
    G
  40. #79
    Gryphon001's Avatar
    Jun 2009
    303
    Quote Originally Posted by brissett View Post
    Cheers for the help
    From what I understand the holes are already there but plugged. The wireing for the doors however is not, so you would have to run wires to the doors. There is a thread on the Fortitude forum somewhere about putting in some footwell lights but never found anything about pudle lights. All other lighting will work fine and for the interior you don't need resistors. That only applies to the outside lights like the plate light and the side markers.
    Hope that helps...
  41. #80
    Jul 2009
    London
    41
    thanks gryphon that info clears things up a little on the work that would be needed.
