fault code on VCDS
kgates
6 in the box
Houston
I am new to the audi seen, but use to own a MK2 golf, mk1v and a mk IV jetta PDTDI. I have just purchased a 2006 A3, and ran VCDS and am having problems figuring out what my electrical problems are on central convience and passenger door.
Belowe is my last scan.
Saturday,15,November,2008,08:37:21:62531
VCDS Version: Release 805.1
Data version: 20080823
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUNF78P66A002043 Mileage: 80810km/50213miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 B HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0080
Revision: --H10--- Serial number: AUX7Z0E2FNH04O
Coding: 0103010A18070160
Shop #: WSC 25101 444 52946
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021126
Shop #: WSC 06314 000 00000
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH14 0180
Revision: 167903 Serial number: 8P0820043H
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 A HW: 8P0 959 655 A
Component: Airbag 9.41 H10 3250
Revision: 91H10325 Serial number: 0035W0000WB/
Coding: 0032605
Part No: 8P0 910 339
Component: BF-Gewichtsens. 01 0020
Coding: 00032605
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 C HW: 8P0 953 549 C
Component: Lenksäulenmodul H21 0050
Coding: 0002042
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 HW: 8P0 920 981
Component: KOMBIINSTR. VDO H73 0300
Revision: D06 Serial number: 2242ED06001791
Coding: 0004263
Address 56: Radio Labels: Redir Fail!
Part No SW: 8P0 035 186 F HW: 8P0 035 186 F
Component: concert II US H51 0410
Revision: 02S Serial number: AUZ5Z6E6014277
Coding: 0001005
Shop #: WSC 06435 000 00000
Saturday,15,November,2008,08:44:46:62531
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Coding: 0021126
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H35 1102
Revision: 00H35000 Serial number: 00000001655019
Coding: E18C5F82C014100000181800180000000028FE375C1100
Shop #: WSC 06314 000 08192
Part No: 8P1 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00150573
Shop #: WSC 06314
1 Fault Found:
00984 - Left Tail Light (M4)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 209
Mileage: 80530 km
Time Indication: 0
Date: 2008.11.04
Time: 12:53:00
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
ON
Coding: 0032605
Coding: 00032605
Coding: 0002042
Coding: 0004263
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 250010530901D8
Coding: 3D3F0342072102
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D06 Serial number: AUX7Z0E2FNH04O
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0040
Coding: 0000025
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.7 1502
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 D
Component: 02 KSG H04 0050
Coding: 9AC003382D08850FC88F447300
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH03 0180
Revision: 00002 Serial number: 10000001229904
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
Part No: 8P0 959 802 E
Coding: 0000025
1 Fault Found:
00936 - Electric Window Switch in Front Passenger Door (E107).
008 - Implausible Signal - Intermittent
Coding: 0001005
Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 B
Component: Tuer-SG 010 0030
Coding: 0001176
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 B
Coding: 0001176
Are you noticing any actual symptoms? For example does the tail light actually work? Have you had any problems with the electric windows?
Yeah have you cleared the scan & seen any repeats of the thrown codes?
Sorry, changed the tail light, works fine. I havent cleared the codes, I will try that first. Makes sence, new car... tought remembering to keep it simple.
thanks
