Volks AutosChris Nott
Page 1 of 2 12 LastLast
Results 1 to 40 of 51
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    A favour please from someone with factory fitted RNS-E
    Would somone mind letting me have their chassis number so that I can look up the antenna parts that are fitted and see if I can't get to the bottom of this antenna fault code that everyone suffers on retrofitted units.
    PM if you prefer.
    Thanks.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    26,762
    If you mean by resolving this then its just a change in antenna systems needed, no doubt a change of the 3 amplifiers in the rear boot lid/end & maybe some cabling changes will resolve this, I doubt the rear window intergrated antenna will need swapping out, I know on my S4 it had the 2 rear side windows with antennas in aswell as the rear, idiot who installed my rns didnt connect the diversity antenna in the rns & only realised when after a year of **** radio I checked behind the radio, but on the A3 its not quite as bad, thats the only way to do it I believe
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Thanks Nigel.
    I've been looking at the parts installed in my car and according to ETKA I don't have an amplifier installed in the tailgate. I do apparently have an amplifier under the seat which is linked into the phone system.
    Stu.
    26,762
    Thats very strange, I would think you have the diversity system in your car mate, I mean its a new car, if you do then you must have the amps in rear.
    Yeah you'll have the compenser amp for the prep for sure fella, but dont think its under the seat, bluetooth goes under the seat mate, it should be rear quarter behind the side panel in boot or is yours sportback as Wesley has this aswell in that place.
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    No it's not a SportBack. I did email Kufatec about the part they offer but they say that it is for SportBack only.
    I do have diversity as there are two antenna plugs at the Radio end so I would think it does use the rear leccy window.
    Looks like I might need to remove the tailgate trim, don't fancy that though.
    Stu.
    Sem
    Sep 2004
    297
    Is it just the error code you're getting? has your FM reception deteriorated since fitting the RNS-E?
    2008 (58) Audi A3 2.0TDI S-Line
    Phantom Black, Xenons, RNS-E etc...
    2008 Audi S3
    Oct 2007
    South Africa
    197
    Look on navplus.us, they fitted a part from the Golf5's aerial and make the error go away. Costs around 100 pounds or so, really not worth it as it just affects FM reception in any case (ZF open circuit error)
    2008 Audi S3
    Oct 2007
    South Africa
    197
    2008 Audi S3
    Oct 2007
    South Africa
    197
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Quote Originally Posted by Sem View Post
    I have the fault code and deteriorated FM reception.
    Quote Originally Posted by sakkie69 View Post
    It may improve the reception but it doesn't clear the code. For the moment, and until I have discovered that it's not feasible then I'm looking to clear the code as well.
    Stu.
    26,762
    Yeah as Stu says the golf 5 mod doesnt clear the fault anyway, its a case of swapping out parts & possibly rewiring, if the golf 5 mod is 100 then I'd rather spend the 100 on the proper fix not the improv job.
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    So anyone want to get me a chassis number?
    Stu.
    Dec 2007
    166
    Stu, check out this thread, it might answer some of your questions.
    RNSe retorfit in 2007 A3/S3 ZF short to earth
    2007 S3 8P, Phantom black, REVO stage 2+, Milltek TBE, EVOMS, Autotech fuel pump, Forge "twintercooler", Forge DV, Forge shortshifter, Black optics, Privacy glass, Buckets, RNSe + SDS, Bose, iPod, FBMFSW, F&R armrests, Cruise, Interior light pack, Auto lights and wipers, Flat tyre warning indicator, Lamin-x, BBS CH's, H&R ARB's, H&R coilsprings
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Thanks, Ideally I need a chassis number so I can look up and compare what's fitted to a factory fit car and my car.
    Stu.
    Dec 2007
    166
    I thought the fix got rid of the fault code, could be wrong! Have a look at this.
    Converting Symphony II+ antenna system for use with RNS-E
    GeoffT's Avatar
    Aug 2007
    Exmouth
    267
    Quote Originally Posted by VRStu View Post
    I think we must have a lot of politicians on here - lots of answers but not to the question asked!!!! (including me now, ironically!)
    Hope someone can help you, as the "ZF to ground" error was one of the reasons I decided to give up on my retro-fitted RNS-E, so I understand your desire to find a solution.
    A3 Sportback Sport 2.0 TDI 140 Mauritius Blue, Black/Grey matrix, GSM prep in armrest, MFSW, 17" 16 spoke wheels, Acoustic Parking rear, Cruise, Non-smoking pack, Symphony II+
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    The 'fix' using the module from a Golf, connected into the existing wiring, doesn't alleviate the fault code.
    I'm really kinda hoping that it can't be that complicated, even if you have to mount a new unit and run two new antenna cables from it to the RNS-E it wouldn't be that bad.
    If anyone is concerned about some sort of security issue over passing a chassis number to me, it's nothing I couldn't get if I saw your car parked in the street (It's visibly mounted on the dashboard)
    Stu.
    Sem
    Sep 2004
    297
    Can you check your local dealers used stock? see if they have any A3's with RNS-E fitted then take a trip down to grab the chassis number from the windscreen.
    I'm off to my local dealer later so i'll see what they have. I'm very interested in this as i'm looking to install the RNS-E very soon.
    gr1zly's Avatar
    Nov 2007
    Poland, Cracow
    207
    I've got thesame problem as you, on monday I will know how to solve that problem.
    If someone need VIN number of cars with serial RNS-E:
    WAUZZZ8P79A007292
    WAUZZZ8P89A013375
    both are 2008 S3 sportback
    2005 A3 2.0TDI S-line quattro
    2007 S3 silver 300Hp
    2008 S3 sportback SprintBlue: Bucket seats, magnetic ride, RNSE, BOSE, Bluetooth, Carbonspeed CAI, Forge BOV... SOLD
    2009 A4 3.0TDI Ibis white with some goodies
    2011 S5 Sportback Sepang Blue with Milltek Race Exhaust
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    I've been collecting some chassis numbers but sadly without conclusive results -
    Mine -
    22 08 07 Build - Has 8P0 035 503L Antenna,
    All 3 doors S3 with factory RNS-E -
    15 01 07 Build - Has 8P0 035 503L Antenna, No Lower Amplifier, 8P4 035 225 C Left Upper Amplifier. 8P0 035 192 L RNS-E
    24 05 07 Build - Has 8P0 035 503L Antenna, No Lower Amplifier, 8P4 035 225 C Left Upper Amplifier. 8P0 035 192 L RNS-E
    27 05 07 Build - Has 8P0 035 503L Antenna, 8P3 035 225 or 8P4 035 225 D Left Lower Amplifier, 8P3 035 225 B or 8P4 035 225 B or 8P4 035 225 C Left Upper Amplifier.
    11 02 08 Build - Has 8P0 035 503L Antenna, 8P3 035 225 Left Lower Amplifier & 8P3 035 225 B Left Upper Amplifier. 8P0 035 192 Q RNS-E
    Stu.
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    WAUZZZ8P79A007292 has a build date of 30 06 08 Can't see anything about antenna or amplifier.
    WAUZZZ8P89A013375 has a build date of 11 07 08 Can't see anything about antenna or amplifier.
    Both have 8P0 035 192 S RNS-E
    Stu.
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    I wonder if it's linked to the version of RNS-E that you have. Mine is the later 8P0 035 192 Q so it might lead you to think I need 8P3 035 225 Left Lower Amplifier & 8P3 035 225 B Left Upper Amplifier
    Stu.
    Sem
    Sep 2004
    297
    It certainly seems that way from the examples you have posted.
    8P0 035 503L - is this the sharkfin antenna?
    Could it be that one of the amps is for the GPS portion of the antenna?
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    I would have thought the Sharkfin with GPS would have a larger base to incorperate the GPS section of it,all the others I've seen are.
    Just so we all know what we're looking at -
    Stu.
    Sem
    Sep 2004
    297
    Stu, can I PM you my chassis number so you can check what mine has?
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Sure send me an email address as well.
    Stu.
  28. #27
    gr1zly's Avatar
    Nov 2007
    Poland, Cracow
    207
    I've just been to my loclac audi service and they have already solved that problem, you have to buy part with these number:
    8p4 035 225 a
    That's all changing for these will help in 100%
  29. #28
    26,762
    Yes thats the antenna & no gps doesnt have an amp from what I know of, its only the phone that has the compenser(amp) & the radio has diversity amps etc
  30. #29
    26,762
    Quote Originally Posted by gr1zly View Post
    8p4 035 225 a
    As I said antenna systems need changing, namely amps as I'm guessing its using same fakra etc connections on concert 2+/golf 5 antenna systems that have the non rns system
  31. #30
    Sem
    Sep 2004
    297
    8p4 035 225 a
    What is the part, have you installed it and has it resolved the problem?
  32. #31
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    8P4 035 225A is a variation of item 10 in the image I posted above. It's a left lower amplifier for vehicles with Navigation and TV. So yes in theory I can see that it may help but it does kinda depend on what else you have in the car and may need to be combined with a different upper amplifier too.
    gr1zly - Have you had this part fitted?
    Stu.
  33. #32
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    I found a picture of the parts in the tailgate, whether you can fit them or not depends on what you already have fitted so I suppose the only way is to take the cover off.
    Thanks to lonesg for the picture.
    Edit - Also found the colour key -
    FAKRA code B (White): RF output and power supply
    FAKRA Code K (Curry): ZF IF input
    FAKRA Code G (Grey): HF RF output FZV
    Stu.
  34. #33
    26,762
    Curry, lol I like that one Stu, lol
    aha so between us all or more like Stu we have found its all fakra anyway so theoretically if amp was swapped out it would maybe fix these issues
    there's gotta be a catch cause the boys audiforum.us would have realised this ages ago, well dirk would have known fairly quickly
    anyway if you've got the time/money you could easily swap out & re-cable if need be fella.
  35. #34
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Another picture of a 225B top amplifier with connections-
    Thanks to kalleu69
    Stu.
  36. #35
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    So who's first to take the tailgate cover off then, Nigel
    There are a lot of people working on this so it does seem as though there is a solution out there somewhere.
    Stu.
  37. #36
    26,762
    might wanna vso image resizer them tad down a bit fella, lol
    which camera you using as thats good closeup
  38. #37
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    They are just hot linked so no control over the size.
    Stu.
  39. #38
    26,762
    uh dont know about you stu me old chap but I'm turning my a3 upside down & paddling down the road at moment I mean WTF its worst than the monsoon I was in thailand with missus, its so bloody wet out there, I'm trying to get my s3 skirts finished, new brakes figure out why suspension has now caused a kinda loose feeling on front, all cant do cause weather & until suspension sorted dont wanna drive at all cause hate it(maybe we could consult on this thing)
    I've got 4 panels of at moment so please someone if you have a garage please feel free, lol.
  40. #39
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Ok, I've resized the images and loaded to my PB.
    Here is another that I found, I think it's been posted before but it might give us a clue as to what extra cabling would be required.
    In my simplistic mind it looks like the need to change the lower amp for a suitable one and then possibly the upper one. Then route the FM1/AM to the lower amp instead of straight to the RNS-E (Maybe a small linking cable) and plug the original FM1/AM into the new amp as the ZF to the RNS-E.
    What do you think ??
    Stu.
  41. #40
    26,762
    Yeah its as I imagined mate, amp switch & small re-cable
    I did reply to above posts but as usual the poxy site crashed so after multiple attempts I gave up, lol
    Ah actually it did post what I said up so cool, ignore above then
