EM TuningMonster Motorsport
Results 1 to 15 of 15
    Fast,not furious's Avatar
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    Low back pressure with TBE
    Now my custom turbo back exhaust has been fitted,(by Exhausts UK,Sheffield)the car's suffering with boost problems. Steve Jr at Statller reckons it's the exhaust that's causing the problem,and recommended putting the old exhaust back on,and then data logging,but obviously that's gonna cost...and then a replacement(maybe my custom one,modified?)or Milltek will have to be fitted again...more money...
    Although it has a 200 cell sports cat,the complete system is flowing too well,so not creating enough back pressure,causing the turbo overboost,so i'm losing torque.
    What should i do? Spend more at Exhausts UK,fitting another cat or something to restrict the flow? Spend even more and go full Milltek?
    I've no idea what i should do next! I've even considered just having the Milltek downpipe and sports cat,but the combination still might not flow correctly with the rest of the system.
    Its currently a 3" downpipe,200 cell sports cat,2.5" pipe,mid silencer,2.5" pipe,cobra rear box.
    I'm running a GIAC hammer map and Forge CAI,both worked seemlessly before the exhaust went on.
    S3 Brilliant Red - 340bhp
    Custom Code Phase 2 + PSS, Autotech pump, Hybrid Forge/ITG Maxogen CAI /Reflactagold, Sprint Booster, Forge Quickshift, Forge DV, Denso Iridium sparks, PCV mod/oil catch can, R8 oil filler cap, Sachs performance clutch,Exhausts UK custom stainless TBE, Braille no-weight battery,PIAA mirror white DRL's,exterior + interior leds, AndyMac's Sub upgrade, H&R springs, VMR VB3 18x8.5 gunmetal alloys wearing BF Goodrich G-force 235/40
    Oct 2003
    up north...
    767
    as a general rule, low back pressure from a highflow cat and good exhaust is usally a good thing - it is going to give you less lag, lower exhaust and turbo temperatures therefore more airflow and pressure with less stress on the engine components.
    what you may need is a custom remap to ensure that you have correct boost pressure and fuelling for the new setup, rather than undo the (presumably good and working properly) effects from the exhaust/cat
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    boggysv's Avatar
    Nov 2007
    572
    <beer induced thought>
    why not try to plug your exhaust outlet and see what happens?
    World's Fastest S3 Driver - racing old people in toyota camries since 1997 with a 97.6% winning rate.
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    jonnyc's Avatar
    Jul 2007
    846
    Quote Originally Posted by boggysv View Post
    Its half 4 mate!! haha..
    MK5 ED30.. Fastest MK5 / 2.0T FSI in the UK - Fastest DSG MK5 in the world!
    12.601 @ 115.85 MPH
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    Could it be the fuel pump??
    May 2008
    349
    i am very dubious as to how good custom systems are, if you look at a miltek exhaust it has been designed and developed for that vehicle.
    On previous cars i have had custom exhausts and they are just made to fit there and then without any development or research into flow rates, where the bends should be etc etc.
    If it was me i wouldnt spend anymore money and go back to std or get a miltek.
    I cant see it being your fuel pump but maybe take it into Audi for a diagnostics check (be prepared to loose your map thoug!!!)
    crazylegscrane's Avatar
    May 2008
    London
    156
    back to standard or miltek and if that sorts it get your money back for the custom exhaust as it dosen't seem fit for purpose
    S3 Sept 08 to.....
    A3 2.0 TDI Sport April 04 - May 08
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    Update...
    It was the fuel pump!
    Exhausts Uk put me in touch with JBS Auto Design,and after a chat with them,the car was booked in for a health check....and the patient has responded well to surgery
    jonnyc's Avatar
    Jul 2007
    846
    Eeeeesh what did I say
    Its a bit of a worry to hear that a fuel pump in an S3 has gone bad though, can you expand on the problems?
    12.601 @ 115.85 MPH
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    Jonny
    Mine was one of the earlier 'H' pumps,which some are having problems with. It seems that it was just unable to supply enough juice for the extra demands the exhaust seemed to make. It was fine before the exhaust went on,so i guess the free flowing exhaust and extra horses were asking more than it could give,hence loss of boost. Logs showed it only able to sustain 110 bar,but with the new pump,she's now holding 140
    jonnyc's Avatar
    Jul 2007
    846
    Ah cool..
    Its more like 110bar and 140bar now.. The FSI fuel rail pressure is immense!
    Glad you got it sorted out anyways mate
    Jonny
    12.601 @ 115.85 MPH
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    That's what i said (does a quick edit!)...i thought that sounded low as soon as i wrote it...no wonder i had problems...lol
    Yeah,it's grand now mate
    jonnyc's Avatar
    Jul 2007
    846
    lol, sorry must have read it wrong
    Have fun mate!
    12.601 @ 115.85 MPH
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    Lol,yeah - i reckon you've been pulling to many G's round the circuit recently and your eyes are still blurred!
