Volks AutosChris Nott
Results 1 to 17 of 17
    Oct 2008
    Rear Wheels Rubbing with Aftermarket Alloys
    Hi there can newbie here, can anybody help i have some new rs4 replica alloy wheels with a bit more offset than standard ones on a facelift s3 and the rears rub when driven a bit firmly .
    I have had a look and it seems as if it could be just a torque screw on the back bumper it just catches on ? Has anyone else had this rubbing when putting spacers on or using these replicas and does taking the screw out solve it or does that hold the back bumper on ? ?
    Thanks in advance
    Great site by the way been really helpful !
    L60N
    I had rubbing on the rear, so took the screw out and filed that bit down. Its done the trick
    P.S. The screw isnt really holding the bumper on, well it is, but removing wont mean it drops down. The other screws hold it tight and its a very snug fit.
    Ive had mine out for a good few months and the bumper is as tight as the day i removed it
    See here: S3 with spacers - RUBBING!!
    Oct 2008
    This is a daft question but did you file the head of the screw or take a chunk off the side of the screw ?
    Would you file it or just take it out ?
    L60N
    I took the screw out completley, but where the screw sits, the bumper part protrudes, so i filed that down flush so it was flat all the way across, Now theres no rubbing
    Hope this helps! - If not, take the screw out and have a look, all will become obvious
    Oli.'s Avatar
    546
    Take the screw out completely, and file down the lug part of the platic bumper - no interference then
    RS4 family wagon.....gone but not forgotten
    Oli.'s Avatar
    546
    jinx
    L60N
    Thats that sorted.
    Hey Oli, have u decided on a car yet??
    Oct 2008
    Thanks for your help, did a dremmel type tool do the job for you then ?
    L60N
    I bought a file 2.99 Homebase!
    Oct 2008
    did you have to have your wheels off and the car in the air ?
    do you think i could do it in situe ? ie leave the screw in and file both the side or the screw and plastic lug at the same time
    jonnyc's Avatar
    Jul 2007
    846
    I run with ET42 18x8 wheels and my car is tucking the tyre by about 10mm at the rear, I get no rubbing after (very neatly) massacring my rear arches, rolled them, cut away all of the material I possibly could etc etc etc..
    I used..
    One of these..
    this..
    And finally..
    Jonny
    MK5 ED30.. Fastest MK5 / 2.0T FSI in the UK - Fastest DSG MK5 in the world!
    12.601 @ 115.85 MPH
    jamiekip
    Oct 2008
    Easy solution here. Stick the correct wheels back on. Why? Cos they are meant to be the ones to use.
    jonnyc's Avatar
    Jul 2007
    846
    Quote Originally Posted by RobErt62 View Post
    12.601 @ 115.85 MPH
    L60N
    If we all thought like we'd be running around in caveman suits, clubbing women, then dragging them off to our cave for a bit off nookie.
    Runs off to put standard wheels on
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    Quote Originally Posted by L60N View Post
    ah the good old days
    Gone A3 TDi S Line DSG Bluefined
    Now Seat Leon Cupra about to be Bluefined
    Nov 2006
    Cheshire
    881
    says who - the internet police? Sorry officer.
    Audi A3 2.0TDI S-Line
    OEM+
    Coming soon: VW Passat 2.0TDI 170 DSG
