Monster MotorsportEM Tuning
Thread: R32 Brakes
    Cali's Avatar
    Jul 2004
    North West
    134
    R32 Brakes
    I have a A3 2.0 TDI (140) Quattro (55 plate) and I have been offered the brakes off a rolled R32. Will they fit and is it worth doing if they do fit. Do I need to do front and rear or just the front. What do I need - is it the carriers and the disc or more?
    I don't know what is on mine (as I haven't picked it up yet - Tuesday)
    I did upgade mine on my A4 Quattro Turbo from 288mm to 312mm but this was fairly simple as it was just swapping the caliper carriers.
    gr1zly's Avatar
    Nov 2007
    Poland, Cracow
    207
    My friend bought brake kit from R32 to his Leon FR, after testing it's huge difrence betwen old breaks and those from R32!
    2005 A3 2.0TDI S-line quattro
    2007 S3 silver 300Hp
    2008 S3 sportback SprintBlue: Bucket seats, magnetic ride, RNSE, BOSE, Bluetooth, Carbonspeed CAI, Forge BOV... SOLD
    2009 A4 3.0TDI Ibis white with some goodies
    2011 S5 Sportback Sepang Blue with Milltek Race Exhaust
    hatmeow's Avatar
    Turbo is the only way....
    Feb 2008
    247
    Its a straight swap but if you are still with 17in wheels I am not sure if it will clear the calipers. If you have 18s then there is be no problem with clearances.
    You will feel massive difference just with the fronts but since your car is a quattro you can also get the rears as well if you have extra cash. I would go for just the fronts and spend the $$ somewhere else.
    Hope this helps...
    A3 2.0T Sportback DSG.
    Engine / Trans:
    K04, Unitronic Stg II+ & DSG Stg II, S3 Injectors and Intercooler, APR F/Pump. BSH Intake, Forge DV, Oettinger Turbo Outlet, Eurojet throttle pipe, Milltek TBE. SP Meth Injection.
    Brakes and Suspension:
    Brembo 6 pot w/ 345mm slotted disks, TT front suspension, HPA Coliovers, OZ Palladio, 225/40/18 BS RE001
    Others:
    S3 Front, Pedals, & Mirrors, 09 SB Skirts & LED Rear Lights, Original HID retrofit, Oettinger Roof Spoiler. Defi Turbo Guage, FBMFSW
    27,129
    yeah I have a set of a3 3.2 brakes that are the same 345mm fronts as the R32 & the S3 & they are supposed to be straight swap, you'll need the the whole front setup, caliper carriers, calipers & discs/pads & dont forget the dust covers as these are different also aswell as all bolts etc, I might fit tomorrow actually if weather is any better than today, freezing my arse of.
