EM TuningSky Insurance
Results 1 to 9 of 9
    Oct 2008
    Telford
    2,484
    Boot wont close!
    So i've had my A3 only 1 week and already there is a problem! The boot wont close properly!
    It takes 5 or 6 attempts to get it to shut, it sort of bounces back off the catch if you know what i mean? I really have to slam it hard and i dont fancy doing that all the time as i might break something
    Anyone know anything about this, maybe a known problem?
    B6 1.8T Avant s line gmbh
    Khufu's Avatar
    West coast of Scotland
    5,693
    not heard of it being a problem. Maybe the latch had moved a bit and needs adjusting?
    wesley's Avatar
    Giac Extreme+!! Lovin it
    Feb 2007
    Manchester
    322
    Yes sounds like the catch has moved slightly,you just need a torx head bit to undo the bolts and adjust the catch outwards towards the back of the car.
    07 Suzuka Grey S3, Giac Extreme plus map, Autotech HPFP, VF Engineering CAI, 18" black rims,factory tints,fbmfsw,Mk 2 RNS-E,CH-LH lights.puddle lights,Bose,Shark fin, Lamin x lights & Fogs.Full TBE miltek, 09 White DIS,Buckets,LED conversion,TPMS.
    Oct 2008
    Telford
    2,484
    ok cool, i'll have a go tomorrow....If I can find my Torx bits!
    Dec 2006
    Ireland
    2,538
    if it is still under warranty you might be best to take it back to the dealer
    Oct 2008
    Telford
    2,484
    Nope its 4 years old, the extra 1 year "approved used Audi" warranty ran out 2 months ago!
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,043
    Used to happen to me everytime I had a body in the boot.
    I had to stop killing fat people in the end.
    Boot works fine now.
    Paul
    26,720
    when you touch the microswitch on boot lid do you hear the click/action ok everytime? Just checking all possibilities, does it bounce back up when closing, is the locking hook closing ok with your hand so lift the lid & pull the hook over in the lock manually & check its actually working then press microswitch to see if it releases ok.
    Fast,not furious's Avatar
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    Quote Originally Posted by Lee_R View Post
    Yup,had the same problem on my 1.8T sport,the dealers replaced something,but i can't remember what. Bloody annoying,isn't it?
    ....hmmm,that was helpful!
    S3 Brilliant Red - 340bhp
    Custom Code Phase 2 + PSS, Autotech pump, Hybrid Forge/ITG Maxogen CAI /Reflactagold, Sprint Booster, Forge Quickshift, Forge DV, Denso Iridium sparks, PCV mod/oil catch can, R8 oil filler cap, Sachs performance clutch,Exhausts UK custom stainless TBE, Braille no-weight battery,PIAA mirror white DRL's,exterior + interior leds, AndyMac's Sub upgrade, H&R springs, VMR VB3 18x8.5 gunmetal alloys wearing BF Goodrich G-force 235/40
