EM TuningChris Nott
    maars's Avatar
    Full speed ahead
    May 2007
    567
    Exclamation Removing front grille without removing bumper?
    I seem to remember a post a while back where someone managed to swap the front grille without removing the bumper. I can't seem to find it. Does anyone remember how it was done?
    Daytona RS4 Avant :: black optics
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,788
    Here a link to how you do it: http://forums.fourtitude.com/zerothread?id=3756530
    But all it really says is:
    1. Need two people
    2. Remove the three torx bolts on top
    3. Remove the plate filler thing, then remove the chrome trim ring by going along the inside edge and popping out the tabs..dont force this...
    4. Grip the slats on the bottom of the grill and pull with some force (they will pop out.
    5. Have the other person hold the bumper while you pull the grill in the same manner all around
    6. On both sides towards the bottom there are 2 stupid plastic screws from the inside out one on each side (this is why Audi says remove the bumper). Stick a long screw driver down there and pop out the screws. (this things is held in be 18 snap things and 3 huge bolts these little PLASTIC screws are over kill and need to go)
    7. Get out you new grill and snap it in the the bumper, pressing firmly to ensure all are in all the way
    8. Tighten down the 3 torx bolts and BAM you done. This took me and a friend 20 mins total time to do..
    Hope this helps
    Ashley
    I cant spell !
    Jun 2007
    North West
    434
    MY12 Black edition TT Roadster with a tractor engine !
    maars's Avatar
    Full speed ahead
    May 2007
    567
    Perfect, thank you both!
    maars's Avatar
    Full speed ahead
    May 2007
    567
    Next question...is it possible to remove the chrome surround with the grille still attached to the car?
    I cant spell !
    Jun 2007
    North West
    434
    Possibly but I imagine most of the plastic clips that hold the chrome surround will be broken ! Some of the clps are glued as well, If replacing the chrome surround should be ok if careful.
    Richard
