AH FabricationsEM Tuning
Results 1 to 20 of 20
    Oct 2005
    London, UK
    7
    MTEC hids killed my wiper motor
    Hi
    I have an Audi A3 Sportsback 2005 model 2.0T sport I have had it from new but unfortunately I did not purchase xenons. I tried an aftermarket hid kit after several weeks of driving the hid killed my wiper motor. Luckily the car was still under warranty so I managed to get Audi to replace the motor.
    After researching this forum it seemed common consensus that the minimum requirements for hid upgrade is to use projector lenses and the best aftermarket kit is MTEC. So I purchased a set of FK Angel eyes and MTEC 6000K hid kit. The kit was installed over the weekend and I was very impressed with the light output, cut off and no glare.
    However, today, jumping in my car to drive 25 miles home in the rain I switched on my wipers and yes they had died less than 24 hours after the install.
    I was under the impression that the wiper motor died due to cheap hid kits, which the MTEC is not.
    My car is now out of warranty and will have to pay 200 for a new motor.
    So can anyone help, why does the motor die with aftermarket hids and not with oem xenons?
    Is there anyway I can get my kit to work?
    Khufu's Avatar
    West coast of Scotland
    5,693
    Im a bit confused as to what the lights have to do with the wiper motor or am I missing something?
    Oct 2005
    London, UK
    7
    Well this is the second time I have installed HIDs and each time the wiper motor dies. It is either coincidence or I am very inlucky. If you do a search on this forum you will see several references to this problem.
    27,121
    Well I would put the lights back as they were & go back to the warranty company & say the wipers arent working now after you installed the new motor, just blag it they will think oh must be shagged motor, we're change it again as there will be warranty on that work anyway, so soon after the motor change they shouldnt question it & you just need to plead ignorance, I assume you've still got the old lights, also check with Ian@ www.hids4u.co.uk, he seems to know fair bit about hid's etc so maybe he can help you.
    Could be the headlights are on the same circuit as the wiper motor so maybe its not liking the electrics now lights changed, do you use any resistors etc, is it just a plugnplay kit?
    Khufu's Avatar
    5,693
    mmm, made some intersting reading! I retro fitted S3 Xenons to my old 8P A3. I powered them via a relay straight to the battery, appears this isnt a solution either. I want Xenons for my current A3 but was planning on getting the Audi ones.
    Nov 2006
    Cheshire
    881
    sorry I cant help, but when i was looking at getting a HID kit a few sites did warn about a wiper motor dieing if you fit HID's, dont ask me why, but ive heard about the problem before. One of the kits i VERY nearly bought was the MTEC, glad I opted got uprated Osram bulbs now!
    Audi A3 2.0TDI S-Line
    OEM+
    Coming soon: VW Passat 2.0TDI 170 DSG
    27,121
    Quote Originally Posted by Khufu View Post
    Best option for the 8P is the kufatec looms & use the oem xenons, that should resolve any issues with the wiper motor
    (Front suspension changed)
    Khufu's Avatar
    5,693
    I see they are offering digital ballast that supposidly dont interfere. On a related note, my wipers have stopped a few times....
    ....they started up again ok. Once they stopped just as the fuel warning light bleeped on..
    27,121
    here you go this should resolve motor issues:
    http://www.hids4u.co.uk/store/produc...&cat=16&page=1
    Oct 2005
    London, UK
    7
    I have just called hids4u regarding there ultimate kit and guess what, they told me that there is a problem with installing there kit on the A3 as it blows the wiper motor.
    Looks as though this is a well known problem.
    It seems as though fitting a relay harness may solve this problem.
    Jay.Ing's Avatar
    Jun 2008
    North West
    274
    If you fit a relay harness you will get a bulb out warning unless you install some capacitors!
    2012 A3 Ibis White SportBack Black Edition 140 - Going..
    Stuff for sale:
    Number plate LEDS
    Brand New Pipercross Panel Filter
    Light/Rain Sensor with Loom
    50mm H&R Suspension Kit
    Brand New H&R Springs (50MM)
    OEM Auto Dimming rearview Mirror
    Concert III with Aerial amps
    Red A4 Black Edition 150Tdi.... Arriving 29 July!!!
    Gone But Not Forgotten....
    2011 A1 Black Sline 106
    2006 A3 Red Sline 140
    Lukeyb's Avatar
    Oct 2008
    100
    i have had this problem, i bought the ultimate kit for the reason it said they were ok for use with the A3, which is renowned for having a sensetive wiper motor, mine blew and i had to buy a new one they wouldnt even look at it after they saw it had non audi hids. Supposedly the lights and wiper motor run on the same circuit and are sensetive as feck.
    i took the HIDs off in the end and got offered my money back off hids4u as they werent fit for purpose, i still have the relay set for running them off the battery though, it doesnt give bulb out warnings as it still uses the standard bulb connections to supply the on/off signal to the relays which then take power from the battery
    27,121
    strange as it says it will work, oh well at least they refunded ok, oh well kufatec loom & original oem's will do the trick guys for sure.
    Oct 2005
    London, UK
    7
    So does running the lights of the battery also kill the wiper motor?
    27,121
    doubt it as power is supplied via the battery direct not through the original light supply, but no doubt blown bulb warnings will be an issue unless you use resistors
    Lukeyb's Avatar
    Oct 2008
    100
    they sent me the relay kit after i had the problem through the normal wiring, through the relay harness it takes main feed from the battery, the original light power connections only feed the relays to open the main circuit from the battery when you want the lights on so supposed to be absolutely no issues when using the relays
    Nov 2008
    hi all,
    been experiencing the same problem, driving in the rain without wipers 3 days already :S
    i heard from the boys at local by adding some what value resistor would help, but nobody has the stock resistance value for the ballast to calibrate the resistance, is there any new update to solve this....
    tks
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,974
    Quote Originally Posted by Black.on.Black View Post
    IF iuse aftermarket hid kit and relays and capacitors will i still have a problem with wiper motor and bulb warning?
    vw754's Avatar
    Nov 2006
    U.K
    1,974
    hid's failed..wiper motor?
    those of you who have used aftermarket h.i.d's and have had a wiper motor fail, have you got 'AUTO HEADLIGHT SWITCH/AUTO LIGHTS????
    Lukeyb's Avatar
    Oct 2008
    100
    i didnt get a bulb warning ever, it all worked seemingly ok then blew up, hids4u said you cant blow your wiper motor with the relay kit installed, but id removed the hids by the time they sent me the relays so dont know
