AH FabricationsVolks Autos
Results 1 to 9 of 9
    Sep 2006
    Surrey
    1,224
    Unhappy Continuous Engine Coolant Temp. Sensor Problem - PLEASE HELP!
    I'll get straight to the point. In August the car was playing up which was closely followed up by an Engine Management light on the dash.
    Symptoms were:
    - Overly underpowered.
    - Cold air through air con despite turning the temp as high as 26!
    - Very rough drive with revs dropping sharply during gear change.
    - Alot of rev play during idle.
    - Fan at the front of the car would spin up extremely fast!
    Took the car in to the garage and we hooked it up to a diagnostics tool. It came up with the Engine Coolant Temp Sensor.
    So we changed it and it fixed the cold air through the air con but car was still rough and still under powered.
    Took it in again with the same fault. Now there were 2 things that could be changed. The Engine Coolant Temp Sensor and the Thermo Stat Sensor.
    So we changed the Thermo Stat Sensor too. It fixed the problems above for a very short while then I got the same symptoms again when just a couple of days ago the Engine Management light came on.
    Took it in and the result was Engine Temp Sensor Circ. So basically the same thing. Gonna go through the whole car again incase it's a faulty sensor but could it be something we've missed?
    The Air Mass Sensor & EGR Valve has been already changed in May so surely can't be that.
    One other thing, recently I noticed a pattern with the car. During idle, the engine coolant temperature will slowly rise to 90, then the car will make a distinctive judder and the rev line will start bobbin up & down and that the same time the temperature will hit 0 (60). Friend at the garage said that it seems like it's saying that too much power is being fed to it. The fan at the front of the car still also spins up EXTREMELY fast despite the air con being off or on econ.
    Sorry for the story, i've tried to keep it short but it's as if were coming out of ideas
    Please help!
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    Before you spend any money, check all the fuses and check the engine throughly for loose connection and split hoses....
    Also, try resetting the car by disconnecting the battery for over 30mins.
    But Id double check the temp sender as it keeps coming up and see how that goes!
    Unfortunatly, not been with the A3 Long but my golf had similar symptons minus the fan and powerloss and it was the temp sender...
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Are you using genuine parts?
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    Khufu's Avatar
    West coast of Scotland
    5,693
    I'd look for a split hose too. That could affect the idle and maybe underpowered if the turbo isnt working properly due to an air leak? Its a major pain to sort when you get problems like these!!!
    Sep 2006
    Surrey
    1,224
    Ok we'll check all the fuses and the temp sensor again. We've already changed the turbo hose but will check to see if it's fitted properly.
    I mean my friend at the garage is a cool guy. Clued up etc but he only runs it, doesn't actually do the work himself but he's gonna go through with it with me and the mechanics together to be sure.
    Thanks for all the help guys. Much appreciated
    9
    Hi There, I have an a3 1.6se with exactly the same proble, do you remember what it was that fixed it it at all? and help would be greatly appreciated!!!
    Thanks,
    Nikki
    wesley's Avatar
    Giac Extreme+!! Lovin it
    Feb 2007
    Manchester
    323
    which engine coolant sensor have you changed as there is 2? G62 and G83?
    07 Suzuka Grey S3, Giac Extreme plus map, Autotech HPFP, VF Engineering CAI, 18" black rims,factory tints,fbmfsw,Mk 2 RNS-E,CH-LH lights.puddle lights,Bose,Shark fin, Lamin x lights & Fogs.Full TBE miltek, 09 White DIS,Buckets,LED conversion,TPMS.
    9
    I changed g62, didnt solve it, think it may be the thermostat now, so getting a new on of them, but its electric one so it comes part of a housing for about 60
    Sep 2006
    Surrey
    1,224
    Mine still isn't completely solved.
    It blows out hot air etc but, it's very weak. It doesn't blow out as fast as it used to. I give up =(
