Chris NottSky Insurance
Results 1 to 18 of 18
    27,075
    Bilstein B6 or Koni FSD & which ARB's????
    I'm getting my new eibach springs so taking chance to do shock upgrade as I hate stock ones, they are truly ****e.
    So I have been interested in Koni FSD's & also Damian@dpm has mentioned Bilstein B6's are much better, anyone chirp in on this please??
    Also is there any ARB's I can upgrade on my a3 2.0 TDI DSG that would improve the car overall, seen a few but would like feedback from people with upgrades on.
    THanks.
    27,075
    anyone????
    Oct 2003
    up north...
    767
    i have fsd after reading a lot of reviews and i think they are very good if yours springs arent too hard - a good compromise for road and a lot smoother than the oem stuff.
    i did a long post about suspension options including ARBs
    most kits seem increase the front more than the back proportionately, where as with fwd cars you want to increase the rear much more than the front.
    probably the best but most expensive are the neuspeed front and rear are 25mm with 2 way adjustable - use rear at stiffest and front at softest.
    there is a new make that do 27mm front and rear, 3 way adjustable, which i would go for if i were starting again.
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    27,075
    aha it be you, lol, many thanks fella, which make is that do you remember?
    Yeah I will be getting the eibach pro 30mm in day or so & they arent really hard at all from what I've been told.
    Boydie
    Would you not also consider an eibach anti roll kit to thicken up the stock roll bars?
    I am considering a set!
    27,075
    I'd consider anything as long as functional boycie, check your msn left message on for u when doing final parts of wheel.
    I've found H&R kit for 300, neuspeed was 400 from awesome, but thicker the better for rears I guess given fwd as Dunk says
    Oct 2003
    up north...
    767
    hotchkis 27mm front and rear
    front adjustable +45%, +70 and +105%
    rear adjustable +90%, +125 and +200%
    i would set the rear at 200% and the front at probably +70 for road
    www.hotchkis.net
    TT-RS 410hp revo
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Fiat Punto GT 130hp
    Mini 74hp
    A4_DTM's Avatar
    Dec 2006
    Croatia
    97
    Don't buy Eibach pro kit, it will lower your car minimal and it will still look to tall ! Take Sportline and some better shocks. My friend has it on 3.2 quattro and he bought now D2 coilovers which are way better investment!
    27,075
    I'm not buying to lower though fella, I'm buying to improve the ride & comfort, I'm not into lowering anyway, just oem is ****e, but thanks for the info anyway.
    Shocks are what I need to decide on thats why FSD's or Bilstein B6's
    Oct 2003
    up north...
    767
    the eibach -30mm springs are really quite good - they lower a bit without being slammed, but the ride quality is improved even over SE/standard - very hard low springs will reduce grip on anything other than a mirror finish road
    TT-RS 410hp revo
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Fiat Punto GT 130hp
    Mini 74hp
    27,075
    I only want a better ride, height doesnt bother me so much & everyone says the 30mm eib pro's are good enough to improve ride over oem sport springs, will get some shocks aswell, leaning towards fsd's
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,289
    If you're getting the Eibach Pro springs then why not get the Pro dampers to match? Very good kit and a better choice to the FSD's.
    Damian @ DPM
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    27,075
    Ok I have gone with Eibach Pro's 30mm with the Koni FSD's as Bilstein are harder ride & I'm not into the lowering to the floor & air cushion for my arse cause of a hard ride, so combination of FSD's with these springs seems to be the ticket, thanks to Dunk for his input.
    But expecially hats of to Damian@DPM, has been great service, rang him advised look Bilsteins not really what I want, can he get FSD's, he advised yes but not what they usually stock, he said he'd ring Koni, low & behold come back to me short while later said can get for cheapest price out of everyone & done the deal with springs, all within what an hour or actually less.
    To compare Awesome GTI were emailed yesterday & still havnt had a reply, that to me is not what I regard as good service, if I'm dropping 600 on parts & probably more I expect a reply by now even same day tbh on these kinda things that they advertise as stocked, DPM didnt stock but had it done in no time at all, now thats unbeatable service & I will be going back to him for my ARB's & other stuff if he can get.
    That shows a willingness to help & provide top notch service, thats the reason why I went to him cause his input on AS from what I've seen has been top class, always willing to help, not always chasing a sale which is a sign of an enthusiast aswell, of course they are there to sell but he has proven beyond a doubt my money belonged with him.
    & to Damian.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,289
    Thanks for your kind words Nigel, much appreciated as is your business.
    Thanks again,
    Damian @ DPM
    DPM Performance
    T: 01207 561606
    27,075
    Hey it isnt a lie is it, I'm to the point & blunt fella, no time for BS, your service was 1st class & I wanted people to know it, I wanted some products you got in record time, be delivered in next few days I hope so cant get better huh, wish the stealers were the same.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,289
    DPM Performance
    T: 01207 561606
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    let me know how you get on, I managed to drive over some dips in the road and I feel like i've broken my back, well not quite broken but i'm having to lie down on a hard floor as my back is killing me.
    Gone A3 TDi S Line DSG Bluefined
    Now Seat Leon Cupra about to be Bluefined
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    I have KW V2s and H&R ARBs, hope that helps? Handling is superb! Love it.
