Volks AutosAH Fabrications
    Jun 2006
    Aberdeen
    30
    A3 2.0 TDI fan problem
    Hi Folks,
    i'm after some advice. the problem is with my girlfriends 2.0 TDI, the fan has started coming on intermittently even when the car isn't up to temperature. My first thoughts would be that it is something to do with the thermostat.
    anyone had problems with this or know what the problem might be?
    Gogs
    Current
    2007 Imola Yellow S3, 1983 Mk1 Golf GTI
    Previous
    2005 TT Quattro Sport
    1999 Imola Yellow S3
    1999 Mk4 Golf GTI 1.8T
    Sep 2006
    Surrey
    1,224
    Yep I had the exact same problem. Well mine would spin up really really fast. Quite audible even inside the car.
    We changed the Engine Temp. Sensor and it fixed the problem. Although there's another closely related problem (which i'm getting done tomorrow) which is the Thermostat Sensor.
    I know this because we hooked it upto a diagnostics program and it gave a fault code. The fault code gives 2 possibilities:
    1) Engine Temp. Sensor
    2) Thermostat Sensor
    Hope that helps
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    PW-Motorsport's Avatar
    Jun 2006
    Pembrokeshire
    389
    This could also be due to the aircon.
    The aircon system will switch on the fans if the system pressure builds. This can happen in the first few seconds of startup.
    Switch the aircon off, select econ and see if the fan kicks in?
