Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    RGC
    RGC's Avatar
    I void warranties"!
    Aug 2008
    NORTH EAST UK
    146
    Cool RADWELD RADIATOR LEAK SOLUTION
    Hi,,
    well i have a leak on my 2.0 TDi radiator,,, small leak nothing major just a small patch of coolant under the car when morning comes,
    was wondering if it would be OK to use a fix additive to the coolant to sort it?
    radweld or something similar
    http://www.halfords.com/webapp/wcs/s...tegoryrn_58760
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,758
    i used radweld for my polo 16v a few years back and it worked a treat!
    Highwayman's Avatar
    Feb 2008
    Down South
    140
    Personally, I wouldn't, as how do you know that the stuff only adheres to the leaking area? You will have the stuff floating around your system until you next change the coolant and it could, at least in theory, decide to attach itself anywhere.
    These products are OK to get you home if you have a leak, so that they are only in your system for a few days and you can then wash them out when you repair the leak properly. IMHO, they shouldn't be used for a long-term solution...get the leak fixed/replace the radiator .
    Phil
    Sprint Blue S3 with silver-grey leather/alcantara, RNS-E with BOSE, FBMFSW and a few stealth mods....
    RGC
    RGC's Avatar
    I void warranties"!
    Aug 2008
    NORTH EAST UK
    146
    will be a big job to replace rad, as air-con will need to be dumped and re-gassed as there are 3 radiators together water/air-con/turbo inter-cooler so looking for quick fix,
    it says on the tin that it's a permanent fix and i can always replace coolant say a week later after its worked... (hopefully )
    Aug 2008
    408
    hi m8, u should be fine to use radweld, ive used it on loads of cars, it wont damage anything in the cooling system, it fixes the leak by blocking the small hole in the rad etc and semi hardens by air activation if u know what i mean .
    RGC
    RGC's Avatar
    I void warranties"!
    Aug 2008
    NORTH EAST UK
    146
    great
    thanks
    PW-Motorsport's Avatar
    Jun 2006
    Pembrokeshire
    389
    Not really ideal.
    It may provide a temp. "get you home repair", chances are the fault will come back when you least need it.
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by Highwayman View Post
    Phil
