Volks AutosJMB Retrofits
Results 1 to 14 of 14
    wesley's Avatar
    Giac Extreme+!! Lovin it
    Feb 2007
    Manchester
    323
    Hex-Usb-can lead for Vagcom
    Anybody wanting to purchase a hex can usb lead for Vagcom,well they normally retail at Ł259 but i managed to get one today with next day delivery for Ł230,this is good discount considering Gendan told me they were the cheapest in the Uk.I purchased the lead from a place called http://www.mi-uk.com/ they are recommended on Ross Techs website as a distribtor.
    07 Suzuka Grey S3, Giac Extreme plus map, Autotech HPFP, VF Engineering CAI, 18" black rims,factory tints,fbmfsw,Mk 2 RNS-E,CH-LH lights.puddle lights,Bose,Shark fin, Lamin x lights & Fogs.Full TBE miltek, 09 White DIS,Buckets,LED conversion,TPMS.
    Dec 2006
    Ireland
    2,538
    That's not using VAGCOM - it is their own version of it called MI DIAG
    It will more than likely do the same thing, but you won't get any support from RossTech. You'll have to go to MI for it.
    Gendan are more than likely correct in saying they are the cheapest in the UK for VAGCOM as MI are not selling VAGCOM.
    Although, from looking at the PDF brochure (http://www.mi-uk.com/products/access...diagnostic.pdf) it would appear that they have rebranded VCDS as MI-DIAG since the windows all look to be the same. Perhaps they have licensed the software rather than just distributing it as is.
    wesley's Avatar
    Feb 2007
    Manchester
    323
    Mark was speaking to Nigel before about this and he said the same so i phoned them to triple check it was definatley a ross tech lead and vag com and he said 100%. Will be getting it in the morning so will let you know for definate,if it isnt then im going to play havoc with Steve at MI!!
    27,097
    The only thing that bothered me from our chat earlier today was the fact it had been rebranded as Marc spotted aswell, this to me is kinda worrying as I never thought vagcom licensed its intellectual property to anyone else, but I've had no need to contact Ross-tech to date so I'm sure you'll be fine, but do check when you get it as advised cause Ł230 delivered in a case was very low indeed, thats why I suggested Gendan in 1st place as guaranteed to be original with all support which Ł30 extra wouldnt have bought anywhere else.
    Update me in morning mate on phone etc if like.
    wesley's Avatar
    Feb 2007
    Manchester
    323
    The packge arrived this morning and was exactly what i ordered,they sent me a small plastic case which contained a genuine ross tech Hex can usb lead,a ross tech binder manual and a ross tech quick start guide,very impressed with it for this price.
    Dec 2006
    Ireland
    2,538
    Jolly good. Have you installed the MI-DIAG software from the CD yet? I'd be interested to know what version they are shipping - is it the latest (805) or are they still shipping 704 or even 603 (603 is listed on their PDF).
    Have they confirmed whether or not you can download the latest versions from RossTech's web site or do you need to run their version only?
    Dec 2006
    Ireland
    2,538
    By the way... looks to be a bargain if they've thrown in the binder and plastic case. Mine arrived in a FedEX envelope which contained the lead inside a jiffy bag and a quick start guide.
    From looking at RossTech's product pages it looks like the plastic case only comes with the pro version.
    wesley's Avatar
    Feb 2007
    Manchester
    323
    they shipped the 805 version but i instalalled the latest 805.1 from ross techs site,been playing with it all morning and eventually afetr a bit of head scratching seemed to of activated all what i wanted doing,there is a few error codes on there which im not sure what the problems are if u can shed any light on it?
    VCDS Version: Release 805.1
    Data version: 20080823
    Saturday,04,October,2008,12:03:06:29101
    Chassis Type: 1K0
    Scan: 01 03 04 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 76 77
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 1010
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0050
    Revision: 5BH16--- Serial number: AUX7Z0G4FNM0Q3
    Coding: 01030003180F0060
    Shop #: WSC 06314 000 00000
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Revision: 00H13001
    Coding: 0021128
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
    Component: KlimavollautomatH19 0420
    Revision: 080100 Serial number: 8P0820043AH
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000007095873
    Coding: 958E0F27A0141000470000000000000000194E175A05000000 0000000000
    Shop #: WSC 06314 000 08192
    Part No: 8P2 955 119 E
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 N HW: 8P0 959 655 N
    Component: Airbag 9.41 H01 4230
    Revision: 91H01423 Serial number: 003CR0G011FW
    Coding: 0071612
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0004012
    Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.lbl
    Part No SW: 8P0 920 981 L HW: 8P0 920 981 L
    Component: KOMBIINSTR. VDO H20 0630
    Revision: D0H20001 Serial number: 2244G001000705
    Coding: 0005404
    Shop #: WSC 00779 210 83394
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533__Gateway H15 0180
    Revision: H15 Serial number: 1400K074098123
    Coding: E9831F0E4006020101
    2 Faults Found:
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 45
    Mileage: 17496 km
    Time Indication: 0
    Date: 2008.10.01
    Time: 15:42:06
    01044 - Control Module Incorrectly Coded
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 42
    Mileage: 17496 km
    Time Indication: 0
    Date: 2008.10.01
    Time: 15:43:22
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 L
    Component: Haldex 4Motion 0116
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D0H20001 Serial number: AUX7Z0G4FNM0Q3
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 L HW: 8P0 035 192 L
    Component: RNS-E HIGH EU H73 0550
    Revision: 02S Serial number: AUZBZ7G0905227
    Coding: 0205711
    Shop #: WSC 32590 126 86229
    4 Faults Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 17601 km
    Time Indication: 0
    Date: 2008.10.05
    Time: 09:01:24
    Freeze Frame:
    Mileage: 17600 km
    Count: 510
    Clock: 09:01
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 17601 km
    Time Indication: 0
    Date: 2008.10.05
    Time: 09:01:16
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 17601 km
    Time Indication: 0
    Date: 2008.10.05
    Time: 09:01:16
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 17601 km
    Time Indication: 0
    Date: 2008.10.05
    Time: 09:01:13
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX.lbl
    Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
    Component: Tuer-SG H02 0040
    Coding: 0000560
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.069 H08 1901
    Shop #: WSC 00652 210 91743
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 F
    Component: KSG H05 0070
    Coding: 9880202002586D298D0DC89AC677
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Coding: 0000560
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 F
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000012
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205711
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 17601 km
    Time Indication: 0
    Date: 2008.10.05
    Time: 09:01:24
    Freeze Frame:
    Mileage: 17600 km
    Count: 510
    Clock: 09:01
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 17601 km
    Time Indication: 0
    Date: 2008.10.05
    Time: 09:01:16
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 17601 km
    Time Indication: 0
    Date: 2008.10.05
    Time: 09:01:16
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 17601 km
    Time Indication: 0
    Date: 2008.10.05
    Time: 09:01:13
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
    Component: Parkhilfe 4-Kan H09 0070
    Revision: 00H09000 Serial number: 00067824830713
    Coding: 0000113
    Shop #: WSC 131071 1023 2097151
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 K HW: 8P0 862 335 K
    Component: FSE_255x BT H26 0340
    Revision: 00000000 Serial number: 00000005141974
    Coding: 0001222
    Dec 2006
    Ireland
    2,538
    have you retrofitted the RNS-e? The ZF ground to earth is normally the giveaway there. You also appear to have a problem with the wiring for two of your speakers.
    The 205711 coding also appears to be incorrect. That's what the fourth error means.
    Dec 2006
    Ireland
    2,538
    Since you've only just got your lead, I would assume that is why the coding is incorrect.
    You'll find the full listing here: http://www.navplus.us/forums/showthread.php?t=62
    Your problem would appear to be the third last digit (7).
    It needs to be one of the following:
    0xxx?xx: Telephone/telematics
    1 - no telephone (supply voltage for microphone actively)
    2 - Mobile phone preparation (Temic - Speisesp. Microphone inactively)
    3 - Mobile phone preparation (Cullmann - Speisesp. Microphone inactively)
    4 - Mobile phone preparation (Nokia - Speisesp. Microphone inactively)
    5 - Telematics Europe (supply voltage microphone inactively)
    6 - Telematics US (supply voltage microphone inactively)
    7 - Base plate diagnostic capable with comfort control
    The RNS-e is not aware that it has phone capabilities. If you have phone prep then you need to change the 7 to either 2, 3 or 4.
    If you don't know which one you need then you should make the change, clear all errors and then do another scan after closing the controller in VCDS.
    wesley's Avatar
    Feb 2007
    Manchester
    323
    yes fitted the rnse the other day!! not sure what the fault with the speakers would be,i onlg got vagcom this morning so do i need to code anything/remove any wires from the rnse??
    Dec 2006
    Ireland
    2,538
    Yeah, you'll need to change that 7 anyway. everything else should be ok, unless maybe the unit you bought was a LHD one which means the nav lady will be on the passenger side. You can recode this by changing adaptation channel 136 to 13. It will be 5 if LHD.
    not sure about the speaker errors - do you have BOSE?
    27,097
    Wes I thought the coding fault cleared fella when you rescanned several times?
    Speakers open circuit suggests short somewhere, but they worked fine when we tested as did all quarters independently
    Antenna put down to the diversity antenna systems from symph 2+ to rns
    wesley's Avatar
    Feb 2007
    Manchester
    323
    Yes Marc i have bose.
