Volks AutosJMB Retrofits
    Oct 2006
    a3 2004 plate rattle
    hi i have a ratle sounds like coming from dash board area above glove box its driving me nuts has anyone else got this i have removed glove box and left it at home but it still does it help help i cant turn radio up anymore
    27,094
    so you saying the radio isnt audible at same time as the glovebox noise started, maybe a loom come loose to me, remove radio fella & check for a plug thats come out, sounds like this
    Oct 2006
    no nothing to do with radio i tried that!!! it sound like its coming from a pillar near tax disc
    DeckedS3's Avatar
    Apr 2008
    South East
    551
    Its not the sun visor jumping about is it?
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    Boydie
    Does your glove box drop when you open it or slowly lower?
    If it drops straight away your lowering mechanism is broken - common fault and rattles like fook! I havent bothered to fix mine yet
    Simple solution, turn up the volume!
    27,094
    He removed the glovebox & still does
