Sky InsuranceChris Nott
Results 1 to 11 of 11
    dantdi's Avatar
    Feb 2008
    kent
    511
    Question When hot starting taking 8 sec+
    Hi all
    when driven my a3 2.0 tdi for more the 15min to normal temp. Trying to restart car before it cooled down seams to struggle any ideas?
    Starts fine when cold.
    Dan
    dantdi's Avatar
    Feb 2008
    kent
    511
    YEA BUT NO BUT YEA
    Nov 2007
    Norway
    46
    How's that pressure test of your engine worked out?
    I'm not saying it's related but it can be - I once a had a lancia delta hf integrale, I blew the head gasket on that engine 3 times.
    Every single time before it happened I got coolant or/and oilproblems and then problems staring the engine when hot before the engine failed totally.
    Usually game over in the morning when cold actually.....
    After a few years I considered myself a master in changing the engine head gasket in that cramped integrale engine compartments :-)
    That 2 liter lancia engine was a marble, the most entertaining and sporty enginge I've ever driven, as long at is was working mind you. I wish I could have a flawless working lancia 2L 16v turbocharged engine in my A3 - that would have been great
    Well, back to your engine - A human with a cold doesn't like to run, A sick engine will not accecpt to be pushed hard.....
    I say get your engine sorted before chipping it or you might be sorry....
    2008 A3 2.0 TDI S-line
    27,097
    ye good point what happened on pressure test & as already stated dont chip until fixed.
    dantdi's Avatar
    Feb 2008
    kent
    511
    The pressure test come bk all ok. What else can i do tho?
    cheers for getting bk to me
    DIESEL POWER's Avatar
    A3 2.0 TDi IMOLA YELLOW
    Oct 2006
    13
    I have noticed similar symptons on mine for some time. Will start from cold nearly instantly. When warm it turns over for longer before starting, it is noticeably longer but ive never timed it. Don't think it would be quite 8 seconds. No faults on Vag Com.
    Above a certain temperature the glow plugs are not activated. Maybe this has something to do with it.
    Any one else with similar symptons?
    A3 2.0TDi SLINE..IMOLA YELLOW..LEATHER/ALCANTARA INTERIOR..18" ATP INOX ALLOYS..K&N PANEL FILTER..15mm H&R WHEEL SPACERS (rear).
    dantdi's Avatar
    Feb 2008
    kent
    511
    sorry women moment. About 3 - 4secs. I know the car never use to do it when first got it.
    I've heard that about the glow plugs too.
    Nov 2006
    51
    Its the starter motor, no doubt. Mentioned by my audi chief mechanic. Told me that this also used to happen in the older A3 and Golf. You need a new starter motor, but with a modified reference.
    Aug 2008
    408
    have u vagcommed the car m8? that may tell u whats going on?
    27,097
    3-4 secs to start, are you kidding me, if it were like 10+ then I'd question it
    dantdi's Avatar
    Feb 2008
    kent
    511
    Well maybe its just me then but dose take longer.
    What think about pressure test being all ok?
