Sky InsuranceAH Fabrications
Results 1 to 15 of 15
Thread: RNSE problem
    gr1zly's Avatar
    Nov 2007
    Poland, Cracow
    207
    RNSE problem
    I have bought RNSE navigation after buying car, and I have problem with quality of radio station I see lot of them but sound isn't clear. In VAG-com there is an error with amplifier.
    I have question for those of you who have bought RNSE with car, can you give me your VIN number so that I could check list of parts which are thesame and which are diffrend.
    2005 A3 2.0TDI S-line quattro
    2007 S3 silver 300Hp
    2008 S3 sportback SprintBlue: Bucket seats, magnetic ride, RNSE, BOSE, Bluetooth, Carbonspeed CAI, Forge BOV... SOLD
    2009 A4 3.0TDI Ibis white with some goodies
    2011 S5 Sportback Sepang Blue with Milltek Race Exhaust
    JohnS3's Avatar
    Oct 2004
    3,021
    The amps in the boot lid are different for the rnse. You should have a HF and ZF connection for the rnse, but the symphony ii+ and concert ii+ cars has two HF connections. This is where you get the ZF short to earth issue I assume you have found.
    Get a coffee and read this...
    http://www.navplus.us/forums/showthread.php?t=6292
    JohnS3's Avatar
    Oct 2004
    3,021
    This explains it better. Taken from the above thread. The golf diversitybox I and others have used doesn't appear to fix it completely, but my FM reception is certainly improved.
    JohnS3's Avatar
    Oct 2004
    3,021
    Thanks for the PM Gr1zly. You mentioned your fitter just plugged in the RNSe, he should have moved the bose wire in the quadlock, see pic.
    He should have also coded the RNSe for bose. The coding should be 0xx9xxx and also adaptation channel 8 should be set to 255, that way you wont see the GALA menu on the RNSe. It should also sound a lot better!
    gr1zly's Avatar
    Nov 2007
    Poland, Cracow
    207
    I forgot to say that he has code everythink. But as I said there is only one ERROR with amplifire...
    27,028
    Have to ask but have you got the diversity antenna adapter plugged in to the rns at rear in the twin antenna socket as this is what happened to me on my S4 B6 the installer didnt connect this at all.
    The amp wont throw any errors as it doesnt have any diagnosis wires, no canbus, do you mean the rns is throwing an error, what is the error?
    JohnS3's Avatar
    Oct 2004
    3,021
    The 07 8P and onwards have a new antenna system when a ii+ headunit is fitted so there is no diversity adapter as such. It'll be the RNSe logging a "ZF short to earth" or "ZF open circuit" depending on whether the second antenna wire is plugged in or disconected.
    gr1zly's Avatar
    Nov 2007
    Poland, Cracow
    207
    The error is only on when you plug computer with VAG-com.
    RNSE is working very good as navi, cd, and phone.
    Only problem is not good quality of sound on the radio.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    John
    With the BOSE how does the audiopilot work then when connecting the RNS-E?
    Just when craig fitted mine the microphone for the audiopilot does not go anywhere and has to be taped up. As you say there is no menu for GALA now so was wondering what happens, mine does go quiet sometimes when I slow down (not all the time) but seems to turn up quite often when going over noisy road surfaces?
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Sem
    Sep 2004
    297
    John, would you say the diversity box restores FM reception to the same quality you previously had with the Concert/Symphony?
    When you say 'it doesn't fix it completely', are you referring to the ZF error code? That I can live with but poor FM reception I can't.
    2008 (58) Audi A3 2.0TDI S-Line
    Phantom Black, Xenons, RNS-E etc...
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by JamS3 View Post
    John
    Hi Jamie,
    As I understand it, audiopilot is part of the Bose system, there is another mic in the car which listens to the background noise and turn the volume up or down accordingly. I'll stand corrected on that though.
    Not too sure about the wire you mention, but if Craig (S8Craig I presume) can't find a home for it, then there probably isn't one!
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by Sem View Post
    Same quality as the sym ii+ unit? No, it not quite as good as that. But the RNSe is an old piece of kit now.
    It does fix the ZF error code until you start the engine... Then it returns.
    Without the golf diversity box I experienced what could be described as static/hiss on some FM stations in a dip on a road close to home when the car is moving. With the diversity box fitted I no longer hear the hiss when traveling on the same road listening to the same station.
    You can see the ZF values changing in one of the engineering mode screens. It would be good if someone without the golf diversity box (Jamie I'm thinking of you!) could look to see if the ZF values change whilst driving around.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Quote Originally Posted by JohnS3 View Post
    Hi Jamie,
    The wire he taped up I'm presuming was the other end of the mic that went into the radio and registered/told the noise to go higher/lower.
    The standard radio I took out had a AUTO function on the GALA menu and worked well but now on the RNS-E it seems to be less frequent.....
    gr1zly's Avatar
    Nov 2007
    Poland, Cracow
    207
    I've been today at my local dealer I checked my car VIN numebr and VIN of S3 sportback with original RNSE and amplifire is thesame because I've got BOSE.
    Now I don't have any idea what's wrong
    27,028
    Gala from what I recall worked on a speed sensitive function not the background noise.
