Thread: break lights
    audi_driver's Avatar
    S LINE
    Nov 2006
    147
    break lights
    Can i get my breaks light bulb replaced at an audi centre? the reason is I usually go to my local garage but after he did a messy job with his dirty hands with my dad's volvo i dont wanna go there anymore.
    VORSPRUNG DURCH TECHNIK - NEVER FOLLOW
    Dec 2006
    Ireland
    2,538
    yes, but they'll charge you for it. you can change the bulb yourself.
    inside the boot there will be a small cap about the size of a 2 pound coin. if you lift prise this off there will be a bolt behind it. you can remove this by inserting a flat head screwdriver into the slot in the bolt and then gently prise the light out from the inside edge to the outside.
    if you're not comfortable with this then take it to the dealer. they will probably charge you 0.1 hours labour (i.e. 6 minutes or 8) - or you may be lucky and they'll do it FOC.
    S LINE
    Nov 2006
    147
    In that case ill probably do it myself, my local did it for only 2 pound! lol
