Badger5Sky Insurance
Results 1 to 13 of 13
Thread: S3 Dump valve
    wesley's Avatar
    Giac Extreme+!! Lovin it
    Feb 2007
    Manchester
    323
    S3 Dump valve
    Hi all,has anyone got a link to a vid with an 8p s3 running a forge dump valve by any chance as i want to get a D/V fitted but not sure which one to go with,any suggestions would be appreciated cheers.
    boggysv's Avatar
    Nov 2007
    572
    By D/V do you mean dump valve or diverter valve?
    Dump valves dont work well with our engines/computer afaik, but it makes chicks wet...so..it's your call in the end of the day.
    World's Fastest S3 Driver - racing old people in toyota camries since 1997 with a 97.6% winning rate.
    Oct 2006
    Manchester
    724
    Hi
    The 2.0T ones can run the dump valves OK
    No worries on that one
    Have a look on Forge Motorsports web site , as I do know they do have quite a bit of info on there , they also do the adjustable one too
    Sarah
    Highwayman's Avatar
    Feb 2008
    Down South
    140
    Surely the S3 has a dump valve already? Why would you want to fit another one, unless you wanted that rather chavvy 'psssssst' sound . Leave it for the Scooby/Evo brigade IMHO .
    Phil
    Sprint Blue S3 with silver-grey leather/alcantara, RNS-E with BOSE, FBMFSW and a few stealth mods....
    2008 Audi S3
    Oct 2007
    South Africa
    197
    There is mostly just the Forge DV to fit. The latest revision doesnt tear as easily as the old one, and there have quite a few reports of Forge valves which got stuck open or closed. I am keeping with the stock DV for now, while I'm under motorplan I will just get it replaced at Audi when it (if) it breaks.
    2008 Audi S3
    Oct 2007
    South Africa
    197
    Quote Originally Posted by Highwayman View Post
    Phil
    It has a diverter valve, instead of venting excess boost to atmosphere (for pssst) it returns it. You can add the Forge spacer which vents and makes that noise, but the amount of air in the system is metered - so if you vent some air the car will be running lean for a little bit every time you vent (ie change gears)
    wesley's Avatar
    Feb 2007
    Manchester
    323
    Quote Originally Posted by AwesomeSarah View Post
    Hi
    Sarah
    Do they sound good sarah and do they affect the performance at all?
    wesley's Avatar
    Feb 2007
    Manchester
    323
    Quote Originally Posted by boggysv View Post
    Meant a dump valve boggysv
    Fast,not furious's Avatar
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    ?? ...ermm,how come mine makes this phsssst noise (i don't think its quite as noticable as the Scoobies and Evo's)
    Im running the standard OE diverter,but the noise started happening immediately after installing the Forge CAI.
    Theories? Does anyone else with a CAI notice this?
    S3 Brilliant Red - 340bhp
    Custom Code Phase 2 + PSS, Autotech pump, Hybrid Forge/ITG Maxogen CAI /Reflactagold, Sprint Booster, Forge Quickshift, Forge DV, Denso Iridium sparks, PCV mod/oil catch can, R8 oil filler cap, Sachs performance clutch,Exhausts UK custom stainless TBE, Braille no-weight battery,PIAA mirror white DRL's,exterior + interior leds, AndyMac's Sub upgrade, H&R springs, VMR VB3 18x8.5 gunmetal alloys wearing BF Goodrich G-force 235/40
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    Quote Originally Posted by Fast,not furious View Post
    You will just be hearing the turbo spooling through the new filter as theres less restriction etc now.
    2003 Audi S3 + Go faster bits
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    I heard the turbo spooling when i had the map put on,it's a different sound to the one i'm hearing now,this one's much louder and a different pitch,it's a definite whoosh,usually when i come off the gas to change gear?
    Oct 2006
    Manchester
    724
    Quote Originally Posted by wesley View Post
    Hi
    No it wont affect performance at all
    Sarah
    May 2008
    Switzerland
    108
    Quote Originally Posted by sakkie69 View Post
    If you dump some air, you'll be running rich, not lean...
    S3 8P + Milltek non-resonated exhaust = Fuel-to-noise converter
