Volks AutosMonster Motorsport
Results 1 to 17 of 17
    Apr 2004
    49
    Problem on my A3 HELP NEEDED
    Hi guyz, recently purchased an A3 3.2 DSG (love it to bits)
    It developed a problem last night while driving along at 40mph, the car started to shake a little bit, like a loose wheel, not through the steering so I can only assume its something to do with the back on the car, so I pulled over checked all the wheel nuts which were tight so I drove on, the vibration continued only after about 35mph I sped up to 70mph and it was better but still there,
    Is it a wheel issue do you think? Or something to do with the rear diff?
    Thanks for your help!!
    Boydie
    Could be a bearing or a loose shock/spring
    What year is the car? do you have warrenty?
    I would definately get it checked out though
    DeckedS3's Avatar
    Apr 2008
    South East
    551
    How bad is the vibration?
    Could just be the that some of the lead weights to balance the wheels have popped off.
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    Apr 2004
    49
    Its an 04, no warranty I'm afraid, could it be a buckled wheel? The vibration gets gradually worse if I stick at the same speed, seems worse when on the throttle slightly, and when I free wheel its better but still there, seems to go away when I start braking as well
    FazS3's Avatar
    Apr 2008
    857
    I had the exact same problem on my golf vr6 it turned out to be the bearing!you could check it just put both hand around your tyre and try to move it side to side if there is excessive movement then it should be the bearing
    MTM THE ULTIMATE STAGE!
    Apr 2004
    49
    I tried that mate, both back wheels are solid and don't budge at all, they don't seem to make any kind of noise either when you spin them, I also checked for loose driveshafts and there both very tight
    Boydie
    Could it be the exhaust rattling off the bumper my any chance?
    the rubber dampers could have perished that support the exhaust mounts at the back
    Apr 2004
    49
    Could that cause the whole car to shake?
    Apr 2004
    49
    Looks far worse than first thought, checked both wheels, there fine, all hub and bearing seem ok, fearing it could be the prop shaft or 4WD system at fault, if anyone has any advice what I can check next? cheers
    Apr 2004
    49
    BUMP!
    The car does shake violently as well, it starts off slowly but if you maintain your speed the shaking gets so bad you have to stop as you can't see where your going and it feels like the car is shaking to bits, only seems to start happening when the car is warm as well, say after 2 miles? something is out of balance badly on the car just have to figure out what!
    consilio's Avatar
    Up the owls!
    Aug 2007
    Northamptonshire
    659
    Get it booked in and checked over. Regardless of the cost involved, you could end up causing a serious accident or worse
    March 2011 - B8 Audi S4, Ibis White, S-Tronic, Leather / Alcantera Super Sports Seats, Heated Front Seats, Advanced Key, Tech Pack High, Electrically folding and auto dimming mirrors
    SOLD - 8P Audi S3. Brilliant Black, FBMF wheel, Bose, RNS-E, Auto lights/wipers, Cruise control, Tyre pressure monitor, Parking sensors, Interior light pack, GSM phone prep, Armrest, Privacy glass, Electrically folding mirrors.
    Apr 2004
    49
    Its currently off the road and is going into Audi next Monday, just if anyone has advice in the mean time?
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    So theres no noises?
    No bulges in the tyres or anything?
    2003 Audi S3 + Go faster bits
    Apr 2004
    49
    Nope, no buldges or iffy looking tyres/wheels no noises from the bearings or diff, no problems changing gears on the DSG (even from Drive to Reverse) and when you set off its as smooth as silk... until you get to 40mph
    Apr 2004
    49
    Well after all the investigation work and issues with the gearbox, diff, haldex etc, I have figured out its 2 buckled rear wheels! I tried some brand new wheels on the back last night and it didn't vibrate at all!
    Low life livin' the high life.
    Feb 2008
    1,638
    Obvious question....How did you manage that?? And what wheels are you running? OEM or aftermarkets?
    A3 2.0T FSI Quattro S-Line, 3 Door, Avus Silver (special ed.)
    For Sale:
    S-Line gear knob, stick and gator.
    Full set of OEM wheel bolts (incl. locking nuts & caps)
    19" BBS CK's Anthracite - SOLD
    Apr 2004
    49
    Well I've only had the car 2 weeks so it wasn't me! I aasume the previus ownder has drove the car with flat tyres or the wheels have been swapped at some point for a dodgy batch
