AH FabricationsVolks Autos
Results 1 to 9 of 9
    Dorsprung Turch Vechnique
    Sep 2007
    Glasvegas
    162
    Coming Home Lights
    Anyone ever used VAG COM so switch on this function - so that when you open the car you get front and rear lights on till you turn the ignition?
    2003 - A3 Volcanic Black 1.6i 8L
    2004 - A3 Ming Blue 1.8TQ 8L
    2005 - A3 Dolphin Grey 2.0FSI 8P
    2006 - Driving sabbatical ;-)
    2007 - A3 Ibis White 2.0TFSI 8p
    2009 - A3 Monza Silver BE 2.0 TDI 8p
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Yes this can be done VERY easily if you have vagcom.
    Have a look at this thread for details
    Coming Home & Leaving Home Lights Enabled
    Basically in short you need a wiring coming from one of the electrical connections under the steering wheel which needs to be earthed to an earthing point on the car and then enabled on vagcom.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by RobinA3 View Post
    ...unless you have bi-xenons, in which case it only takes a bit of coding!
    8P2 S3
    Aug 2008
    46
    I'll be getting my facelifted A3 in about a month!
    I was wondering if it was possible to turn the CH/LH function ON so only the LED's would stay ON?
    Dec 2006
    Ireland
    2,538
    nope.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Quote Originally Posted by staz1000 View Post
    thats not true, i have bi-xenons and just doing the coding doesn't make it work, the earth wiring needs to be done too.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by MarcQuinlivan View Post
    nope.
    lol
    8P2 S3
    Aug 2008
    46
    nope.
    LoL
    Any other way to turn it on?
    Dec 2006
    Ireland
    2,538
    nope.
