Anyone got that combination of the Bluetooth OEM module & The Samsung Tocco(F480) cellphone??
Apart from the now well documented call cut of/signal issue which funny enough is what the iphone 3g has had, urm I wonder same chipsets?
Anyway, back on track.
If so when you make a call in the car does the car through the speakers for approx 3 seconds make a loud noise & no I dont mean the bluetooth on/off bong, I mean when you make the call & the connection seems to be utilised you get this loud burring noise which goes after few seconds then the call is processing/ringing.
Had before on a previous cellphone & also used different cellphone aswell with no problem like this.
I'll re-pair but just wanted to know if anyone else had same issue?
