AH FabricationsChris Nott
Results 1 to 12 of 12
    I'mRonBurgundy?'s Avatar
    Lets make that kitten purr...
    543
    McGard Locking Wheel Bolts
    I need a set basically. But what size?
    Recently purchased some 10mm (front) and 12mm (rear) spacers and I have OEM 5 arm (RS6 style) wheels.
    Looking on the TT Shop I can specifiy: Original/Radius Bolt +10/12mm, which I guess is what I'm after. However, can anyone confirm exactly what a size bolts I need?
    Ron
    2008 A3 1.8T FSI S-line Phantom Black, Bose, iPod Dock, Front Centre Armrest, Storage Pack, Aluminium Pedals, H&R Spacers, Eibach Pro's, Ambient Lighting, Pressed plates with Ingolstadt surrounds.
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    I would measure the thread on the bolts that you had prior to the spacers and add the spacer size and you should be fine.
    Then go for the nearest length that they do, it is a tricky one as you need enough thread to be safe without too much and it screwing out the other side of the hub.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    Low life livin' the high life.
    Feb 2008
    1,638
    Quote Originally Posted by I'mRonBurgundy? View Post
    Ron
    Well i've just got some 15mm spacers for the back and 10mm for the front. Not fitted yet though but the locking nuts i've bought are as follows:
    M14 x 1.5 (thread pitch) and a 45mm thread length with a standard 17mm Audi radius seat.
    As they come in 4's you have to work to your longest size required. In my case this is 45mm. Obviously the front nuts will extend a further 5mm into the hub but it won't interfere with anything. In fact i bought a full set of 16 45mm bolts to go with the locking nuts.
    Hope that helps a bit!
    Paul.
    A3 2.0T FSI Quattro S-Line, 3 Door, Avus Silver (special ed.)
    For Sale:
    S-Line gear knob, stick and gator.
    Full set of OEM wheel bolts (incl. locking nuts & caps)
    19" BBS CK's Anthracite - SOLD
    27,089
    well you need 7 turns on the bolts anyway but logic suggests as mentioned, add the spacer width to the existing bolts & then order that size or just over.
    Paul your 15mm spacers will rub no or rock hard suspension?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I have 10s front and 12s rear and I have M14 x 1.5 McGards.
    The part number is 28025.
    8P2 S3
    543
    Thanks guys.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    I will be getting some Merc Locking wheel nuts McGard 28017, these are 45mm long so its good for the 15mm spacers.
    http://cgi.ebay.co.uk/MCGARD-LOCKING...d=p3286.c0.m14
    Feb 2008
    1,638
    Quote Originally Posted by nigelhobden View Post
    I'll be honest with you Nigel..... I'm just going to 'suck it and see'. If the 15's really aren't compatible even with a light mod to the lining in the arches i'll get rid and go for 12's.
    Robin..... Have you fitted your 15's yet?? Any major issues?
    For Sale:
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    I've not got them yet, its a part of the group buy and we have been told that the spacers should be with us mid next week.
    Feb 2008
    1,638
    Quote Originally Posted by RobinA3 View Post
    Fair enough mate, let me know how you get on anyway
    For Sale:
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Quote Originally Posted by mitch78 View Post
    I think if I do the same as L60N and remove the screw (or swap i for one with a smaller head) and file some of the excess plastic on the lug away, I'll get rid of the problem altogether.
    no filing needed, the tyres will do that for ya.......................lol
