Chris NottSky Insurance
Results 1 to 15 of 15
Thread: Any good?
    dantdi's Avatar
    Feb 2008
    kent
    511
    Talking Any good?
    http://www.jmdiagnostics.co.uk/01/audi_obd.htm Can any one please tell me if is would be any good or load crap. Or if any has got it and what they think of it ?
    Dose any one know what cable i need for a3 2.0 tdi 2004?
    sound cheap to me but eh.
    Dan
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,721
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    S3-N's Avatar
    Feb 2008
    263
    Quote Originally Posted by mitch78 View Post
    If you're buying anything, I'd go for this:
    http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM
    It seems expensive, but you can actually change things with this, not just read things.
    It gives you the option of clearing any fault codes that may appear, along with the following as a few quick examples:
    • Activate DRLs for either front, or front and rear
    • Change auto-close settings for windows
    • Activate alarm bleeps for open and/or close
    • Make necessary changes for upgrades, eg when fitting sat-nav or footwell lighting
    • Activate the emergency brake flash (when you brake hard, the hazard lights turn on)
    and absolutely loads of other options to play with.
    I actually have a brand new one of these (Rosstech Micro-Can interface and licensed software) for sale
    pm me if you are interested
    Phantom Black B7 S4 + Milltek
    dantdi's Avatar
    Feb 2008
    kent
    511
    Thanks for getting back to me lads!!
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    It's the third brake light isn't it?
    Has anyone actually seen this yet? I did a test on it with my missus but nothing happened. I can only assume it works when the ABS kicks in as it could easily just use the ABS signal to activate it.
    8P2 S3
    S3-N's Avatar
    Feb 2008
    263
    Mitch78: where do you find out where to do all the cool stuff like the emergency brake flash etc?
    mitch78's Avatar
    Mar 2007
    2,721
    Ex 8L S3 driver
    mitch78's Avatar
    Mar 2007
    2,721
    Ex 8L S3 driver
    S3-N's Avatar
    Feb 2008
    263
    A combination of looking through the check boxes in Vag-com and reading useful pages like this.
    Cheers mate
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    No, it's the hazard warning lights that turn on,
    Aha! That makes more sense. Cheers mate
    8P2 S3
    S3-N's Avatar
    Feb 2008
    263
    Found this for the Golf MK5, can't check as my car is with Audi does it look like the same as for the A3?
    http://dpham00.info/gti/vagcom/vagco...0for%20mkv.pdf
    mitch78's Avatar
    Mar 2007
    2,721
    Ex 8L S3 driver
    dantdi's Avatar
    Feb 2008
    kent
    511
    HEX-
    KEY-
    Micro-CAN
    any one know what one need for A3 2.0 140 TDI 2004?
    dantdi's Avatar
    Feb 2008
    kent
    511
    Thanks Mitch have you got this Ross-Tech vag-com?
    Did you get it from Ross-Tech site ?
    dantdi's Avatar
    Feb 2008
    kent
    511
    HA bloody hell. Just look on site the Micro-can-interface is out Stock and discontinued
