Results 1 to 20 of 20
    tobycruse's Avatar
    Jul 2004
    UK
    287
    Went in with engine warning light, came out wthout Ł650!!
    Thats what happened.
    Not so long ago the engine warning light came on on the dash. So, i phone audi and let them have a look at it. First reply was "its been remapped, we arnt touching that!"
    Took it back saying i need it fixed, its nothng to do with the remap, they had a look, and came back with " the whole ECU needs to be replaced!"
    I questioned it loads of times saying i have never heard of an entire ECU being replaced but apparently it happens all the time!
    In hind sight, after the replacement ECU was installed the car is running really well, so it should for Ł650.
    Has anyone else heard of this? An entire ECU replacement? I find it a bit odd....
    Who said speed kills!?!?....But dangerous driving on the other hand....
    Ibis White S3 Sportback - ?bhp - ?lb/ft (Being Fixed)
    Mods: LED's Throughout, Milltek TBE, Revo S2+, Forge CAI (Gold), K&W V3's 25mm, H&R ARB's, Powerflex Bushes, Autotech HPFP, Sachs Clutch, Forge DV, Jonny's PCV Mod, Defi Boost Gauge, Pro Alloy Intercooler, 18" OZ Alleggerita's, NGK Iridium Spark Plugs, VI Performance Monitor, Road Angel Pro Connected
    Full OEM Springs and Shocks for sale from 2008 S3 CLICK ME
    Jan 2007
    Hampshire
    1,155
    Not a common problem, but it has been known. Just hope it wasnt the remap that killed it?! Who was the mapping done by?
    A6 3.0 TDI.
    Iggu's Avatar
    May 2008
    Here
    1,224
    Quote Originally Posted by Issac Hunt View Post
    It says AmD in his sig.
    I once had a fault with my cooling fans in my old A3. I knew the fault was a loose wire which was easily repairable but as it was under warranty I took it in. When I asked the dealer what the problem was he said: "Dunno - we just replaced the whole unit. We don't look at items under warranty."
    I'm sure this ECU didn't need replacing - buut they've got you by the swingers if they sussed it was remapped.
    Phantom Black S3, RNS-E with SDS Hack , BOSE, Sunroof, iPod, ITG CAI, Forge DV, Milltek TBE, Revo Stage 2+, Autotech HPFP, Sachs clutch, Lamin-X, BBS Pescaras, H&R springs, H&R ARBs, NGK Iridium Plugs, Vagcom.
    phope's Avatar
    Aug 2008
    Aberdeenshire
    15
    It's occasions like this, that VAGCOM is invaluable. The cost of a genuine cable and software is a wise investment, considering what cost you've incurred
    At least you have a fighting chance of getting the fault codes read first, and doing a little bit of research on the likely causes of the fault first, before going to a dealer
    Did they provide you with a print out of the stored fault codes?
    2007 Sprint Blue 3.2 V6 TT Quattro with S-tronic and Magnetic Ride
    2008 Dolphin Grey S3 Quattro
    Morgan-VAGCHECK's Avatar
    Foot to the floor
    Jan 2007
    103
    Hmm did they replace the ECU for an internal memory checksum error by chance ?
    I think this is quite possibly going to be the case !
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,050
    How did the dealer know it was remapped?
    Ive never heard of a dealer detecting a remap before?
    In fact Ive never heard of an ECU being changed before?
    It is true thought that dealers rarely do any meaningful investagative and proper old fashioned diagnostic work.
    It a case of old one out, in the bin, new one in and fingers crossed.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Very few things can go wrong with an ECU, problems could be corrupted data and software or something like water ingress.
    Did you get to keep the old ECU?
    tobycruse's Avatar
    Jul 2004
    UK
    287
    I'm not sure how the dealer knew it was remapped, the girl wo ws dealing with my car phoned up and knew....
    I will be investing in a VAG-com when i get my S3 to avoid problems like this!
    I didnt ask for a list of the fault codes, i will do next time, you live and you learn eh?
    What is an internal memory checksum error? I know a checksum is a code to ensure the other parts/code of the ECU are working correctly by spitting out the correct sum, but not sure what a memory checksum error is?
    tobycruse's Avatar
    Jul 2004
    UK
    287
    Quote Originally Posted by RobinA3 View Post
    Should have asked for it! Do you think it would look good on my wall?
    Khufu's Avatar
    West coast of Scotland
    5,693
    Quote Originally Posted by tobycruse View Post
    I'd want it back, take it to who remapped it. If nothing else they might be interested in looking at it to see if it may have had anything to do with the remap.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    I would have it back to make sure that they have actually changed the ECU and also you could see it could be reflashed if the data had been corrupted.
    S3 Big Andy's Avatar
    Stealth Beast Baby Yay
    Feb 2008
    Bramley Hants
    707
    Pretty sure amd would want to know and may well have fixed it for you cheaper.
    I have told my dealer mine is re mapped, and I tell them to prove to me my re map caused the problem, so far everything has been done under warranty!!
    Phantom Black, Revo, 450+ BHP , Milltek Evom's, Autotech fuel pump, RS4 brakes 18" Pro Race 1.2 team Dynamics, H&R ARB's, Bilstein PSS10's, Forge Twintercooler, GT3071R, RS4 Injectors, Helix racing clutch, Custom downpipe de-catted straight pipe to back box, 12.6second 1/4 mile! 4.03 sec's 0-60 This isnt just any car, this, THIS WAS the Stealth Beast!!
    Gone but not forgotten
    VCDS GONE TOO
    http://www.andyoram.co.uk
    Foot to the floor
    Jan 2007
    103
    Its exactly what it describes..
    Get yourself down to the dealers ask what faults were stored that deemed it neccesary to replace the ECU, & ask for your old ECU back as someone else has already suggested.
    Jan 2005
    cambs uk
    1,139
    Ł650 for an ECU, how on earth do they justify this for a rather slow PC in a sealed metal box?! They must produce thousands of them!
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    Mate, you should have gone back to the guys that remmaped it.
    I has a similar issue with my uncles LCR and we took it back to awesome GTI and they re-remapped it and the light went off and car was running fine...
    There was also the sensor inthe exhaust that has to be removed or something like that :S
    Ł650 is a lot of money, ring up the guys who remaped it and see what they have to say...
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    shaun@amdessex.com's Avatar
    Mar 2008
    Kent
    99
    Hi
    Sorry to hear about this problem. I have sent you a PM. Please call.
    Will be very surprised if ECU needed replacing? New one on me.
    Shaun.
    AmD Tuning- West Thurrock, Essex 01708 861827- Open Mon-Sat. www.amdessex.com. 1000BHP 4WD Rolling Road-Workshop and Servicing- Mail Order- Remapping from �299. AmD- APR- Milltek- Scorpion- Forge- Superpro- KW- Eibach- AP- H&R+ more!
    Not anymore - Back 2 BMW (shh)
    Aug 2006
    Norwich, Norfolk
    357
    Presumably you should be knocking on the door of the remapper and asking for Ł650?
    tobycruse's Avatar
    Jul 2004
    UK
    287
    Will give audi a call tomorrow and Amd. We will get to the bottom of this. Should have posted the problem on here before hand, feeling a bit gutted now... Hope Audi still have the old ECU and the printouts, surely they would keep them for good measure? Anywho, will write up tomrorow when i know whats what. On the plus side the car is running really well....
    27,126
    Definitely get the ECU back as its yours anyway & let AMD have a nosey at it as its unusual & I'm sure they can check it out & you never know it might get you some money back if they 1st cant provide you with your property so they need to reimburse you for a lost ECU, play that card trust me if you say you want your property & they've binned it then you say well they owe you for that unit, worth a try & 2nd if AMD can prove the ecu could of been rectified or wasnt actually at fault.
    Jul 2008
    cumbria
    255
    Ive just noticed this thread could have something to do with my fault and a few others, toby can i just ask weather your car also had a misfire when the ecu light came on?
