EM TuningBadger5
    Dec 2006
    Ireland
    2,538
    2.0 TFSI Problem
    My brother is getting the following error on his MkV GTI and I can hear boost being dumped while he accelerates.
    Has anybody had a similar problem with their 2.0 TFSI? Does he just need to replace the dump valve?
    000665 - Boost Pressure Regulation: Control Range Not Reached
    P0299 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 135629 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 07:56:02
    Freeze Frame:
    RPM: 5690 /min
    Load: 90.6 %
    Speed: 80.0 km/h
    Temperature: 87.0C
    Temperature: 28.0C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.970 V
    wolfbane1967's Avatar
    Mar 2008
    Sweden
    231
    Sounds like the dump valve has gone
    Audi RS3 2012, Black, Black optik, Recaro, Satnav
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,050
    Faulty Diverter Valves are common on the MKV Gti.
    I had mine changed as a precaution when I had REVO Stage 1 installed.
    They are 25 from VW and arent that tough to fit.
    VW upgraded these at least once by changing the diaphragm material as its a known fault for the diaphragm to split and leak boost. It also has a stronger spring.
    IIRC they are accessed from the driver side wheel arch with the liner and wheel removed.
    Its 30 min job for someone handy with the spanners and a trolley jack. My local REVO agent did mine for me, cost 20.
    As soon as the MK5 have running problems this is the first thing they change as it cheaper than a diagnostic and will need swapped at some point anyway.
    If you get stuck UKMIVS has a MK5 forum which is very good. Loads of help available, if you search `DV` you should access loads of info (and probably loads of my posts/tells of woe!)
    Good luck
    Paul
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,050
    Had rummage in garage and found old DV.
    Perfect working order, only done 15K before I changed it (needlessly as it turned out).
    PM me if you want it and I will drop it in the post.
    cheers
    Paul
    Sep 2007
    171
    yep, its the diverter valve. the rubber diaphragm has torn and boost is leaking out.
    design fault, the dv is located too close to the (hot) turbo.
    my brother's gti has blown 2, for the third one he got some kinda uprated OEM version of it, apparently theres quite a few revisions.
    in case you wanted to see, here is a pic of the last one that broke (apologies for the quality, i don't have a real camera with me now)
